Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
I installed a new cartridge and it still will not print very good
  • 103 Answers
Call kodak and get the printhead replaced free of charge
18004216699
Posted on Feb 10, 2010
Printer: constant check cartridge
Make sure that ALL cartridges are good. Then make sure that the printer driver is properly installed. Make sure that the cable and connections are good.
If all that fails then you have a problem with your printer.
Aug 24, 2015 | Office Equipment & Supplies
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
I have just installed a new black cartridge and when I try to print the printer says 'left cartridge missing'. It is not missing and is installed correctly. If I override the command the print
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Good Luck!!!!
Feb 19, 2013 | Lexmark X5470 All-In-One InkJet Printer
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
How do i switch of align page when installing a new cartridge as it waste paper printing a test page everytime you switch it on. This is for a HP 1300 series
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=238320&taskId=110
Click on the 'Automatically check to see if your driver needs updating (MS Windows Only).' box in order to check for latest updates to your driver.
Unfortunately, I looked over the unexpected page output and it didn't list this problem as one of them.
Does it really print a test page every time you switch it on? Or does it only print a test page after installing a new cartridge?
Definitely, the alignment page should be printed everytime a new cartridge is installed due to variations in manufacturing of print cartridges will throw off the alignment everytime a new cartridge is installed.
I'm not sure about the test page, though.
Good luck on this modification of standard operating of hp printers.
Jan 17, 2011 | HP LaserJet 1300 Printer
Put in new cartridge and unit will not print. Goes through all of the motions but doesn't print. Printed many pages before "low on ink" message. Why does it not print now?
It may be caused by some issues. Check:
* Did you remove the plastic from the connections from the cartridge as the instructions indicates?
* Is the cartridge connector from the printer ok?
* Is the cartridge correctly installed?
* It's a new cartridge? I mean, NEW. Not refilled one or a cartridge that expired two years ago.
* Try running one or two "Clean printer head" procedure to see if ink flows.
Good luck !
Sep 04, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Canon MP470: "Print Head is not installed. Install Print Head"
Some printer brands have a cute scheme that reads a "new" cartridge as good, but the refilled one has a small fuse link that is burned out by the printer. Try factory new cartridges. Unplug the printer power for a bit to reset the printer.
Jul 17, 2009 | Canon PIXMA MP470 All-in-One Printer
How do i change an ink cartridge on a HP PSC 1510 printer
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you lift the print-carriage access
door to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Make sure the paper tray is down and there is letter or A4 unused plain white
paper loaded in the paper tray.
3. Open the print-carriage access door by lowering the door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
5. Pull the print cartridge toward you out of its slot.in-One
6. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector.
7. Remove the new print cartridge from its packaging and, being careful to touch
8. Slide the new print cartridge forward at a slight upward angle into the empty slot.
Using your index finger, push the print cartridge forward until it clicks into place.
If the print cartridge you are installing has a white triangle on its label, slide the
print cartridge into the slot on the left. The label for the slot is green with a solid
white triangle.
If the print cartridge you are installing has a white square or a white pentagon on
its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.your HP All-in-One
9. Close the print-carriage access door.
If you are installing a new print cartridge, the HP All-in-One begins to print a print cartridge alignment sheet.
10. Load the print cartridge alignment sheet on the right front corner of the glass with the top of the page to the right.
11. Press the Start Scan button.
The HP All-in-One aligns the print cartridges.
Good Luck.
Apr 10, 2008 | Office Equipment & Supplies
Installed a brand new cartridge in hp 1040 fax but prints very poorly(light )
remove the new cartridge
TAKE A MICROFIBER CLOTH MOISTENED WITH RUBBING ALCOHOL AND WIPE THE PRINT HEAD ( THE PART OF THE CARTRIDGE THAT CONTACTS PAPER)
REINSTALL THE CARTRIDGE THEN TEST
ALSO YOU MAY WANT TO WIPE OFF THE CONTACTS ON THE BACK OF THE INK CARTRIDE WITH THE MICROFIBER CLOTH MAKING SURE THERE ARE NO FINGERPRINTS ON THE CONTACTS
Dec 03, 2007 | HP 1040 Plain Paper Inkjet Fax
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
60 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
