Question about KitchenAid KBHC109J Convection/Microwave Oven
My oven keeps heating all time. I disconected the electricity and when turn back on starts heating inside again.
    Problem Solver:
  • 9 Answers
Make the technician fix it
Posted on Feb 08, 2010
  • reischka_qtm Feb 08, 2010
    make the technician fix it
Why does my microwave keep running/heating until I open the door? what can i do about it?
Sounds like a problem with the control panel. Further diagnostic testing would be required, however, as there can be other causes.
May 10, 2014 | Oster OGB61101 Microwave Oven
Heat: I placed a microwavable food product in my sharp carousel r-1505. there was a tiny piece of the foil still attached to the rim of the product container. upon start, the foil immediately caught...
Maybe. The presence of metallic material (foil, stainless steel silverware, etc.) in an operating microwave oven creates electric arcs between the foil and the inside wall of the oven. And this can destroy the electric components.
Sep 22, 2013 | Sharp R-1505 Microwave Oven
Our Kenmore microwave oven recently stopped heating. The lights, turning plate and controls all work but with no cooking is occurring. The last time I attempted to heat something up I heard a cracking...
The most likely cause is a bad magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. The cost to repair will a approach a new microwave oven.
Apr 08, 2011 | Kenmore 80412 Microwave Oven
Turned it on to heat food and make a loud noise , did not heat food and have electrical short ordor.
there is something metal inside that is causing this look for any screws or anything that may have been switch with a repair. what happens is the metal causes the microwaves to reflect back to the magnetron instead inside the food causing noises and sometimes sparks and odor. find the metal object remove it and this should solve your problem
Jan 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave is not heating food up. It starts and runs the time but the food is still cold after the time is comlete
Often this is due to a bad door switch located inside behind the area where the door hooks go into the oven. Sometimes, the problem is due to a bad connection or a bad relay on the control board. You can send it back to GE, and it should cost from $30 to $40 dollars to repair.
Dec 07, 2010 | General Electric Microwave Oven
I have a kenmore microhood 63684 turned lites on and can't get them to off,when fan button is pushed fan does not start but when lite button is pushed after fan is energized fan starts real slow and...
What this simply mean is that there has been a problem from the fan either from the wire connection or from the Cole of the fan connected to the fan motor.
There are two ways of over coming this type of problem below are the recommendation to solve the problem
First of all set the oven on self cleaning from the below instruction or make use of your owner manual to operate the elf cleaning
Please after the self cleaning you most allow the oven to cool down to it best before opening
Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
  1. Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
  2. Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
  3. Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
  4. Lock your oven door manually if your model does not lock it automatically when you clean.
  5. Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
  6. Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
  7. Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
SOLUTION 2 IF THE ABOVE RECOMMENDATION DID NOT SOLVE THE PROBLEM
Then you will have to replace the hole of the fan from the oven i.e the fan is need to be service
Hope this help?
Thank you and thank for using fixya.
Nov 26, 2010 | Kenmore 63682 / 63684 / 63689 Microwave...
My microwave MMV5165BAS MAYTAG is not working like disconected from electricity
Remove the cover, find the fuse neat where the word enters and replace it.
a
Oct 21, 2009 | Microwave Ovens
Oven doesn't heat
Did you or the the repair man do a hard reset?
Thefirst thing I would suggest is a hard reset. Unplug the unit for aminute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Plus, I'm assuming your model is actually MMV5186AA, right?
If it turns out to be a bad board, we actually repair those for customers nationwide for $39.95 in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 01, 2008 | Microwave Ovens
Works but no heat
Possibly a blown fuse inside, or a defective magnatron. If you decide to open the unit, please unplug it first!
Geno
Feb 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Open Questions:
KitchenAid KBHC109J Convection/Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
