Question about Frigidaire FEF366 Electric Kitchen Range
I have a frigidaire FEF366ECD Electric stove and the oven is not working when I put the oven on bake the heating element does not light up the only element that does work is the top element of the oven. When push the bake button you hear the beep of the oven but nothing happens, It just does not heat up but when you put the oven on broil the top works can you help me with this problem thank you
2 Suggested Answers
2coolrick
  • 560 Answers
SOURCE: Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Posted on Jul 30, 2009
Oven will not heat at all. Stovetop works fine
Phillip, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oven Wont Heat or Not Working Bake and Broil Element Testing Oven...
Electric Stove Troubleshooting Oven Not Working
Top 6 Reasons Electric Oven Wont Heat Electric Range Troubleshooting
Stove Terminal Block Replacement Frigidaire Electric Range Repair part...
Jun 17, 2016 | Kitchen Ranges
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Jul 27, 2009 | Frigidaire Gallery GLEFM397DS Electric...
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FEF366 Electric Kitchen Range Logo
165 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
