Question about Guillemot Hercules Dualpix HD 4780428 Webcam
I have a ithaca model 49 lever action single shot and it wont eject shells after firing it but it will eject it if i dont fire it,in other words it will eject a live round but not a spent one
There is a lever under the barrel and it is probably worn beyond function or broken off all you need to do is disassemble the gun and replace it. ( get yourself some good brass punches)
Posted on Feb 28, 2010
Testimonial: "sounds good ,i will try it.thanks"
My shotgun is not ejecting the shell-
If what you are saying the empty Shell is still in the open ejection area and another is trying to push in..if so your ejected is either worn or has gunk built up around it or your chamber is dirty and causing the just fired shell to stick momentarily...try firing and eject an empty shell without another feeding in and see if it clearly and quickly ejects the empty..if not it is the ejector or dirty chamber the new steel is spring fed so it should not be the poblem ..you can try another spring and see what happens. My bet is a worn or dirty ejector..or a long shot it may be the shells expanding too much do to age damp etc try different ones..good luck..
Nov 10, 2014 | Optics
How can i find out what length of a shells are ok to use in my Harrington & Richardson arms co. Worcester Mass. U.S.A single shot 410 ga. shot gun
It should be stamped on the barrel. If not, please take it to a gunsmith. He should be able to tell you what lenght of shell can be safely fired from the gun.
Nov 09, 2014 | Optics
Wont eject round after firing
Probably the ejector itself, or the extractor.
You weren't too specific.
Is the round staying in the chamber?
Coming part way out?
Coming all the way out, just not ejecting out the action?
Coming out, and staying in full contact with bolt face?
Coming out, dropping away from bolt face?
Etc..........
Jul 19, 2014 | Marlin 70510 336 Model 336 Lever 30-30 Win...
Shell does not eject slide jams..I pull clip, pull slide back a couple times , shell ejects what is my problem
Hi! Kevin.....bit hard to know !....assuming ammo is correct dimensionally & of good power., & extractor & ejector are in order & chamber is good & slide is free & full sliding......then my first guess would be sticky firing pin not retracting properly thus stymying ejector action.......any stickier & you might get full auto ?......are you puncturing primers ?.. if gas back escape is part of the picture , bullet may not leave barrel . I suggest you do full strip , incl firing pin , clean & remove any burrs ..... worthwhile to run some dummies by hand & see how they behave..........jimbanjo
Jan 16, 2014 | Smith & Wesson SWW-357-R
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
Central pneumatic roofing nailer,where is the nailing ajustments?i should be able to hold the trigger and touch the nose to fire repeatedly but it wont let me.dont see a ajustment?
Not all nailers have the ability to bump-fire. It depends on the type of trigger and the firing valve that the trigger contacts. Remove gun from air supply and remove the nails (for safety). Take a close look at the trigger itself looking for a bump fire setting. It will have a rotary dial to select single or repeat fire. If no setting, look at how the safety foot contacts the trigger's inner trip lever (the trip lever inside the trigger is what actually contacts the firing valve pin). With trigger pressed in, push the safety foot in and notice if the safety contacts the inner trigger lever. On bump fire trigger, the safety foot mech. will push up on the inner lever each time that you press in safety (and you will see that the inner lever will depress the firing pin). On single fire trigger, with trigger pressed, when you push on safety foot, the mech. will not contact inner trigger lever because the lever is too short to allow safety to make contact with it. On single fire triggers, the inner lever can make contact with safety only when trigger is in the resting position. With trigger released, depress safety and notice that safety contacts inner trigger liver and will remain in contact untill you press the trigger at which time the inner lever will depress the firing pin then fall away from safety. If you are a tinker-er, you can make adjustment to inner lever so that it will make constant contact (the rotary dial on triggers that are made to give you a choice of bump or single actually make the inner lever longer or shorter ). If you make any adjustments, make various and numerous tests with-out nails to make sure that it will not fire accidently.
Mar 21, 2011 | Air Tools & Compressors
I bought a Remington 870 at Christmas time. The first time i shot it the shells are jamming in the gun. I took it home cleaned it and oiled it real good. Went and shot it again same problem. Either...
If the 870 is a Magnum model it should accept 3" shells. After making absolutely sure you have an unloaded shotgun, both chamber and magazine are empty, empty, empty, proceed with these few checks.
Assuming it may be a 2 3/4' model, have you double checked on the left side of the barrel near the receiver? There will be gauge and shell length stampings on the barrel. If you are jamming 3" shells in to a 2 3/4" shotgun you will get jams as you describe. Look at the empty shell casings if you have any and see if the shell appears to be damaged from the chambered and firing process. This could also indicate you have a improper shell length issue.
If you are shooting reloaded ammo make sure it has been properly re-sized, crimped and reloaded.
sloppy reloading of shotgun shells can cause jams as you describe. Improperly re-loaded shells can also cause leaks of bb's, (shot) in to the receiver and bore area.
Check for a loose bb. or bb's, (shot) in the receiver and chamber area. A lodged bb. in these areas will cause problems you have described.
Run your fingers along the barrel and visually check it for any slight bulge. If you detect or suspect a bulge do not shoot or load the shotgun until a gunsmith or the factory check the barrel thoroughly. If someone had loaded a 20, 16 or similar smaller guage shell in the chamber by accident and the gun was fired it will usually cause at minimum a stressed and bulged barrel. Many times a slight bulge in the barrel may not be visually obvious.
Most of the time if a 12 gauge shell gets loaded behind that one and fired you will have catastrophic failures, i.e. the gun can blow up and cause serious harm, blindness or even death in rare cases to the shooter. Shooters call this a "20/12" catastrophic failure. This type of accident is not to be taken lightly! this is why shotgun shells of different gauges are different in color normally.
Never ever, mix shotgun gauge shells in a pouch or box.
If you pump the shotgun too easily, (i.e. wimpy) it can jam up. Always pump, "rack" a shotgun with vigor. I'm not suggesting abusive action, just don't be slow or overly gentle with the pump action that ejects a shell and reloads the next one. Something related to this is if your action/slide bar is out of alignment or has become torqued out of it's proper alignment this will cause problems as you have mentioned. The action/slide bar is a long single piece of flat metal that is in alignment with the barrel and is attached to the front forearm of the shotgun. This is the flat piece of metal that actually makes the action open and close as you pump the shotgun. There is one on the left underside of the bore and forearm of the shotgun. When you pump the action you will easily observe it moving with your pumping action.
Check how the empty action feels to you. While dry-firing, (using an unloaded shotgun), does the action feel smooth or perhaps, gritty, sluggish, overly tight? If any of the later the you need to double check for debris, shot, excessive old lubrication, gumming of the action, a bent action/slide bar, etc. A normal 870 has a very smooth action.
Also, check the bore for any obvious nicks or obstructions that don't belong there. A good quality shotgun such as your 870 should operate best with very little lubrication. Excessive lubrication over time can cause gumming up of the receiver area. Also, improper lubrication products. Improper lubrication can cause problems you have described.
I am not a gun smith. I am simply an avid gun enthusiast. If you have any doubts as to anything that you observe while performing these basic checks on your shotgun, I strongly advise you to call the factory or take it to a local gun smith. Many gun shops will give your shotgun a courtesy check over and if you don't find a solution, many times they will within a few minutes. Do not be embarrassed to take the gun in to a gunsmith! Trust me, they will most likely treat you and you gun with respect and courtesy. Otherwise they won't be in business much longer.
If the gun shop fixes your problem make sure and purchase some shells and perhaps something else from them. We must support our small business firearms dealers and gun smiths
Hope this helps you!
Feb 02, 2011 | Remington Shotgun Mount 12Ga Lh, B Square...
My model 742 lever action missfires every 3 or 4 rounds.dimple on spent cartraige is much deeper than missfired shells
This may be an indication of a broken firing pin, dirt in the firing pin channel, or an over oiled firing pin/channel. All will exhibit this behavior. A through cleaning is called for, with dis-assembly to follow for parts inspection.
I have also experienced this behavior from a weak hammer spring.
Oct 10, 2010 | Mossberg Marlin Rifle 992m,989,mossberg...
New 870 express is not cycling low base shells properly
When it stove pipes, does the empty get caught by the next live round coming up on the carrier?
Try firing one round in the chamber and none in the mag and pump like normal.
If it fires and ejects the empty with no ammo in the mag the ejection system is probably fine.
If when you shoot with one in the chamber one in the magazine and it stove pipes you may have a timing problem. The cartridge stop is letting the next shell come into position and start coming up on the carrier to early. This may be fixed by moving the ramp on the action bar so as to get ejection farther along before the next shell is released to the carrier.
Caution, if the cartridge stops are ok and the carrier is coming up to early it is another issue altogether and needs to be looked at by a smith.
Sep 18, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Powder actuated tool wont fire. I think the firing pin is stuck
is this the one you hit with a hammer? if so check to see if the firing pin is hitting the shell rim at all, if it is sometimes you just have to hit it harder, and make sure your holding the shell in position with down pressure on the handle. if it is the gun model then make sure that the safety lever is is reaching the trip mechanism when you are holding it down making ready to fire.
Feb 05, 2009 | Remington Powder Actuated To Power Load...
Guillemot Hercules Dualpix HD 4780428 Webcam Logo
599 people viewed this question
Top Guillemot Computers & Internet Experts
micky dee
Maxx
Level 1 Expert
Avishek Samaddar
Avishek Samaddar
Are you a Guillemot Computer and Internet Expert? Answer questions, earn points and help others
