Question about Zebra Z4Mplus Label Printer
Printer won't print
My Printer won't print when a print job is sent to it. Data light blinks and the printer does feed.
  • 3 more comments
  • walaroo Feb 23, 2008
    I have exactly the same issue; "My Printer won't print when a print job is sent to it. Data light blinks and the printer does feed." I also noticed that the printer seems to be pretty cool for a thermal printer.
  • VILLAPMCI Feb 25, 2008
    I have the same problem...
    Please help
    Villa
    villa@pmci.us
  • Anonymous May 02, 2008
    Thermal transfer mode doesn't print. Labels and ink ribbon is good. Changed it to Direct Transfer (leaving the ink ribbon in, you get an error of course) But in Direct Transfer with the ink ribbon in I can print fonts and setup, looks good print quality. What is going on, looks like print head failure.
  • scanbest May 05, 2008
    Z4m prints out status report, however any jobs sent will just feed the label
  • killebbe May 11, 2010
    This is with the computer not connected to the printer. You don't need to have the printer connected to the computer to make the Zebra 4m printer print. The printer will print internal items like fonts and setup. Of course Thermal transfer doesn't work, and that's the problem.
Printer doesn't print, just feeds the label.
Check your Labels and Ribbon, ensure you have the right ones.
If you have the right ones, here's what you try.
Hit the "setup/exit" button once. Then hit the "+" button repeatedly until you get to Print Meth. It will say Thermal Transfer. That setting can be changed by hitting the select button and the + button. Change it to Direct Thermal Transfer. Then use the setup/exit button to Temporary save the changes. You can change it back to Thermal Transfer doing the same method.
You will get an error, because the ribbon is in. But you can see it it prints.
Try going to the manufacturer website and read the manual about the printer.
If the printer feeds ribbon and doesn't print, more then likely it's a print head problem. When I mean it doesn't print, I mean from the printer control panel without the computer connected.
If you cannot figure out how to print the internal print fonts or setup from the Zebra 4m+ printer, you again need to go to the manufacturers website and read the manual.
Did a little research, appears that I can get a rebuilt print head for about $400. Instructions to install should be with the print head, if not reverse engineering.
Posted on May 12, 2008
    Champion:
  • Zebra Expert
  • 285 Answers
Try to chek if the quere if full or the buffer from the computer is full. if this is ok, try to reset the printer to factory defult.
Posted on May 05, 2008
Does it show an "Out of Memory" message on the display? If so, hitting the "Pause" button will get the printing started although the first label might be blank.
Posted on Feb 22, 2008
Cancel print job with a linux operating system
HI,
You've sent a print job to your printer and the green light is blinking, but the printer is not printing. The light blinks for a very long time.
The blinking light indicates that the printer is recieving your print request and will print shortly. If the document you are attempting to print is very large or contains many graphics or images, the printer must spool this data into its memory before printing. This can take quite a bit longer than usual. PDF files are notorious for taking longer than other document types.
In this case, it is best to wait a period of time before taking action. Give the printer 10 minutes and see if it prints.
If it does not print within this window of time, do the following.
1. In the bottom right corner of your screen, you will see a small printer icon. Double click on this icon to open the printer job menu.
2. You will see your print job located there, with other information, including its status.
3. Select the job by right clicking on it and select Cancel.
4. The job should cancel itself.
5. Unplug the printer, removing all power and leave it sit for a couple of minutes.
6. Plug the printer back in and allow it to go through its start up phase until the "Ready" indicator light is solid. This indicates that the printer is ready to recieve jobs.
7. You may now attempt to print again.
Thanks,
HP Printer Support
Jul 16, 2014 | HP Office Equipment & Supplies
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
My Deskjet 5740 has Resume light blinking, all other lights off. Will not print. Won't let me cancel printer queue. If I push the Resume button, the printer feeds a sheet and halfway through the next...
Sounds like it is expecting a different size paper than you have in it. In the item that you are trying to print confirm the page size. If it is a document that you download or someone sent you it could be in a different page size. To cancel it you will likely have to go into the printer settings and delete it from there then power off the printer and power it back on, this should clear the job. Windows will keep trying to print the job until it is successful or deleted. To see the print jobs double click on the printer icon then just highlight and delete it.
Jan 19, 2010 | HP DeskJet 5740 InkJet Photo Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
Initializing
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
Printer not printing a red light comes on.
first u check the feed roll component.. and remove than refix a connections.. then may be its working.
Aug 05, 2008 | HP LaserJet 2100 Printer
C4 intermec printer
If you're using this printer on a print server then do the following
Turn Printer Off
Disconnect Data Cable
Press & Hold Feed button whilst switching on
Keep Holding Feed Button until test label is complete and light has gone red
Switch Printer off
Reset your Print Server
Plug Data Cable back into printer
Switch Printer on
This should start it printing (unless there are jobs inthe print queue, if there are then they will need to be deleted before printing will commence)
Mar 28, 2008 | Intermec EasyCoder PC4 Label Printer
Paper sensor, I think
check the cable first..and do a test page, if you can without the printer connected to anything.
then, if that all works, we can look elsewhere, no?
Mar 06, 2008 | Lexmark Color JetPrinter Z23 InkJet
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Zebra Z4Mplus Label Printer Logo
1,580 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
