Question about Minolta Optics
I HAVE A MINOLTA STANDARD BINOCULARS EZ 7X50 CLASSIC. * THE BLACK PART ON THE BINOCULARS HAS GOTTEN STICKY. I AM THE ONLY ONE THAT USE THEM. TO STORE THEM I PUT IT BACK IN THE CASE & THE CASE BACK IN THE BOX & PUT IT ON A SHELF IN THE CLOSET. * IS THERE ANY THING THAT YOU CAN HELP ME WITH ON THIS ISSUE ?
  • 112 Answers
SOURCE: The rubber armoring is "melting" or getting all sticky
sounds ike a problem that cant be cured. take them back were you bought them. thats what happens when you buy chinese or japanese procucts.sorry...larry@reichinstruments.com
Posted on Dec 11, 2008
SOURCE: case is "sticky" like glue
The same thing happened with my old Praktica Sport Zoom binoculars, and (in my case) found that the sticky coating could be removed by repeated rubbing with paper towels moistened with methylated spirit ("meths"). SAFETY FIRST: If you decide to try this method and have not used meths before, it is a very flammable liquid, and harmful by touch and inhalation, so please wear rubber gloves and do this outdoors or in a well ventilated place and away from sources of heat or fire. That said, it is cheap and readily available from DIY stores, usually in their painting section.
Posted on May 20, 2009
SOURCE: Bushnell Binoculars
USE ACETONE (FINGERNAIL POLISH REMOVER) PUT IT ON WITH A CLOTH..IT TAKES THE STICKY OFF BUT THE END RESULT ISN'T POLISHED. SO BE EASY WITH THE ACETONE...
Posted on Jul 04, 2009
  • 73 Answers
SOURCE: Binocular repair
Yes they can be but need to be completely taken apart and cleaned. The salt will corrode any metal parts such as screws etc. The water may have left a coating on the internal glass services. Any impurities in the water may cause fungus to grow. Professionally done this will cost a tidy sum so a quote would be best. The warranty wouldn't cover water immersion if they are not meant to be waterproof. You could ask but Minolta no longer make binoculars and have forwarded on their servicing here is the web address
http://ca.konicaminolta.com/support/contact/binoculars/
You may find that for the cost of repair you can purchase a replacement set. Minolta binoculars are heavily discounted now. For sentimental reasons I have paid more than a binocular is worth to have it repaired.
If you are going to buy a new set and still want to try at home....BE ADVISED this may RUIN the alignment and you should ONLY DO IT if you are going to replace them and DO NOT CARE if they end up in the rubbish bin. THIS IS A LAST RESORT THROW AWAY FIX.
Try and unscrew the objective barrels, the ones with the large lens. If they come off you should have access to the inside. If they don't unscrew easily stop. You will damage them. Flush them out with clean water and let them dry naturally. Avoid letting them dry where dust can enter the inside. This may clear the salt from inside them, Depends on how long since they were dropped into the water. The salt may have caused damage to the glass coatings. When dry, screw the barrels back on. You may end up with a double image. This may be able to be corrected by loosening or tightening the barrels. THIS IS A HACK FIX AND YOU SHOULD ONLY DO IT IF THE COST TO REPAIR IS TOO EXPENSIVE AND YOU ARE GOING TO REPLACE THEM.
Posted on Aug 01, 2009
SOURCE: Fujinon-Mariner WPC-XL Lens Cap replacement
You can order a replacement set at: http://www.bakermarineusa.com/index.php?id=17&cat=38&prod=137
Posted on Jun 29, 2010
Value of manon binocular 7x50
Take a look on amazon.. Amazon com binacular. You can find many binaculars with different prices. I hope this was helpful. Cheers
Jan 31, 2013 | Optics
INEED A MANUAL FOR TASCO OFFSHORE BINOCULAR OS36 7X50 RANGE FINDER COMPASS
http://mrcirl.org/whale/Binocularsmanual.pdf, little late, this might help someone out there......
Jun 16, 2012 | Tasco Offshore Binocular Os36 7x50 Range...
Theres is a water spot inside my binoculars..please tell how to clean it.. please..i need to repair it asap..i work 4 navy engineering
when you take it apart you will effect the collimation..not something to do yourself...and you will probably scratch the coatings trying to clean...gl........ capecod389@yahoo.com
Dec 13, 2010 | Zeiss Classic B/GA 525505 (7x50) Binocular
Carl Zeiss blc 7x50 binoculars
They were isued to the German army. My father bought a pair from a destitute soldier sitting on the wharf in Hamburg in 1945. I want to sell them now, but dont know what they are worth.
Jan 04, 2010 | Zeiss Optics
Eye rubber for 7X50 military marine
You can get the green eyecups for the military marine model from steinerpartsdirect.com I can also recommend changing the standard neck strap with a neoprene one for an older Steiner Nighthunter that is non cliclock. Makes for a much more confortable carry. Just make sure it is one that loops and isn't click lock.
Aug 10, 2009 | Steiner Navigator Pro Binocular
I have a Minolta Weathermatic 7x50 binoculars that suddenly I cannot get in focus. Additionaly, I see double on everything I view.
really sorry about that godlen_po. I will report the problem to our support team. Anyways your binoculars requires cleaning. Though they are supposedly water proof they can be affected by conditions like humidity after prolonged use. You would need to take it to proffessional for cleaning. Do not I repeat do not attempt to clean it yourself using water or any other cleaning substance like soap etc., as you may damage the lenses permanently. I screwed up my binoculars this way only to know about cleaning later. If you need any help locating the nearest spot where you can get this fixed feel free to post back. I apologize once again for the incovinience caused. I will verify if its on my side and report to the support team.
Thanks,
Sai.
Dec 29, 2008 | Minolta Weathermatic Binocular
Missing Minolta Binocular eyecup
LOST LEFT EYECUP FOR MINOLTA 7X35 WP.FP CONTACT ME GEORGE COLE AT gcole@san.rr.com THANK YOU VERY MUCH
Oct 09, 2008 | Optics
Binoculars
do you like to read? do you need a good book shelf? sorry thats all they are good for now. they were junk when they were new. dont waste any money on them...sorry...larry@reichinstruments.com
Aug 01, 2008 | Nikon Action Binoculars
Optics Logo
376 people viewed this question
Top Minolta Optics Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Minolta Optic Expert? Answer questions, earn points and help others
