Question about Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round
Hi i'm pretty sure my son has just flushed a baby wipe down the toilet and now my saniflo is making strange noises and doesn't appear to be working properly, how can i check if the wipe has become tangled in the motor? thanks
    Sniper:
  • 82 Answers
Hi, Had this myself with my son a while back!
*** STEP 1 ... DISCONNECT THE MAINS POWER SUPPLY!!!! ***
You'll need to drain the main toilet bowl of water and remove the toilet bowl away from the sanoflo. This may require that you also empty the cistern and stop the water from entering it (do you have an inline valve to the cistern supply pipe?)
When you have emptied the water and removed the toilet bowl there should be a large Jubilee clip attaching the saniflow to the WC waste outlet. Loosten this and remove it so you can see into the saniflo where the WC waste goes.
You should be able to see the object and reach it with your hands. I would suggest wearing some rubber gloves to protect your hands from getting gunk in cuts etc.
If you cannot get to the object, you'll need to empty out the other pipes to the Saniflo and remove the unit. When you have done this you'll need a star driver to open up the unit and get to the object inside. I would suggest that since most of the saniflo range have an internal grille to stop objects such as this actually hitting the macerator that you should be able to reach it just by disconnecting the WC waste connection
If this helps please leave feedback
Posted on Feb 08, 2010
My sanivite is not pumping the water out or its extremely slow
Make sure the vent on top of the unit is not obstructed. Did someone flush something that isn't supposed to be flushed? Baby wipes or feminine napkins are an absolute no-no. If the macerator blades have been tangled from something like these items, it will have to be taken apart to be cleaned. DW
May 06, 2014 | Saniflo & Saniplus& Macerator Pump
Sanipump toilet had a wipe put down it. i have taken the unit off the back and opened it but it wasn't blocked - put hand in and had good feel around! still making awful grinding noise when flushed. any...
it may have something stuck in the blade (on top of motor) or the impeller (at bottom of motor) to get to the impeller the motor complete will have to be removed out of the pump casing. Also check the discharge pipe for any obstructions. Also there is a pump cover plate located at the bottom of the motor and it will cause the unit to make a loud grinding noise if anything is stuck in there.
Dec 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
My daughter flushed he winter hat down the toilet. How do i get it out?
Kids eh?
.. I had my son flush LOTS of wipes down ours ...
Feb 09, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflo stopped working altogether
It sounds like it has possibly failed. Which fuse did you check .. the fused spur from the consumer unit?
i.e. can you confirm that the unit has power to it?
How old is the unit? , has anything gone down there that shouldn't (toy soldiers, wipes ...)?
It may be worth giving it a clean internally. It could be that the pressure switch is gunked up and no longer working, or that the motor has gone.
Feb 08, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Grinding motor will not stop
my son put a wet wipe down the toilet, now it makes a loud grinding noise when flushed
Oct 07, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
Loud grinding noise from unit when flushed like
take the pump out and haul it outside and spray it off and check in the bottom of the pump to make sure there isn't anything stuck in there. then shop vac the bottom of the tank out to make sure there isn't anything funky in there that would get clogged in the pump. sometimes the out let line gets clogged as well you can buy a drain king ( it's a rubber deal that hooks on the end of a hose and when you turn water on it swells up and sprays water out) then stick it in the outlet pipe and let her rip and see if it lets the water through.
Jul 28, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo ejector experiencing shaking when flushed
I have included the installation instructions. It also includes an expanded veiw of the toilet. The troubleshooting area can give you ideas. From what I read, it is possible that something has feel into the grill. Hopefully this helps.
http://www.saniflo.com/pdf/install/PLUS_US.pdf
Apr 18, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo 013/003/005 Sanibest Toilet with Grinder Series Pump in White Round Logo
710 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
