Question about Cuisinart Brew Central DCC-1200W, 12-Cup 12-Cup Coffee Maker
Coffee maker won't start brewing process
The coffee maker's lights and clock all work fine, but it will not start brewing coffee even though the brew light is on. Why won't it start brewing.
    Problem Solver:
  • 9 Answers
Brew light is off
Posted on Feb 08, 2010
Clean light
Hello -
Regarding any coffee maker - some of the water in the reservoir is turned into steam during the brewing process resulting in a smaller volume of brewed coffee.
As for the Clean notice, it may just mean that the coffee filter basket needs to be cleaned. We wash ours every time after we brew coffee. Coffee residue builds up in the filter basket during use.
Best wishes.
Feb 08, 2018 | Hamilton Beach 47950 12 CUP PROGRAMMABLE...
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
Cuisinart COD-4000 Stopped brewing coffee; lost clock and timing
I have no solution, however I have the same problem. Wondering if you have resolved the problem yet?
Feb 16, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
I have a cuisinart coffee maker. I can set the
Unplug the coffeemaker for 20 minutes or longer - not a second less - in order to fully reset it. Then, when you plug it back in, turn the function dial to Clock again. Press and hold the HR button for a few seconds, and then set the hours. It should work now unless it got zapped, as you said.
-Tha Mp3 Doctor
Mar 21, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Cuisinart DCC2000 quits brewing after 1or 2 cups
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Brew Central  DCC-1200W, 12-Cup 12-Cup Coffee Maker Logo
2,682 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
