Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
My user manual of processor is lost what i can do if i change my motherbord
  • 316 Answers
Hello, motherboard manuals usually have instructions how to assembly the CPU.Have you check your motherboard manual?
Posted on Feb 08, 2010
My computer wont power up until i try it at least 20 times. it has a celeron processor. do i need a new processor? or what? i would rather repair it myself.
First open cpu cabinet.
Reattach ATX power connector from smps to motherbord.
Refix RAM memory.
Pull cmos cell from motherbord for 10 minutes.So all settings are defaults.
Pull processor fan and processor then refix both Clean dust from all parts.
Remove pci cards from motherbord.
Make sure motherboard is not ground with cabinet cover.
Then check.
TRy with another RAM .
If still same problem then you need top change your motherboard orm processor.
Let me know if you need further assistance.Thanks for using FixYa.
Nov 25, 2009 | Sony Computers & Internet
Dosen't boot
Open cpu cabinet.
Refix RAM memory.
Reattch ATX power connector from smps to motherbord.
Pull cmos cell from motherbord for 10 minutes so all settings are defaults.
REmove pci cards from pci slot of motherbord then check.
Open processor fan and processor then refix both.
Make sure motherbord not ground with cabinet cover.
Then check if still problems then change ram .check RAM and motherbord separately .
Nov 21, 2009 | HP Computers & Internet
When I turn on the computer I can't see anything. I take off the RAM and turn on the cpu and does not happend anything. What should I do next ?
eset motherbord settings to defaults you can reset with 2 methods.
(1)Pull cmos cell from motherbord for 10 minutes so all settings defaults.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defualts.
Refix RAM memory.Clean dust from all parts.
Open processor and processor fan.
Remove pci cards from motherbord then check.
Make sure motherbord not ground with cabinet.
Nov 16, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Monitor will not diplay, like it's in perment sleep mode. I have unpluged it tried new cables, I am out of ideas, HELP!!
When you power up the computer press F8 key then enter in enable vga mode thne go to control panel and display property then change screen resolution to 1024*768 then check.But if you are not able to safe mode and other menu when you press F8 then follow below steps.1 by 1 and check.
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattach both.
Make sure motherbord is not ground with cabinet.
Let me know if you need further assistance.Thanks.
Nov 13, 2009 | Dell VOSTRO SLIM TOWER and , MONITOR 19...
Ge pro-ht it beeps three times long
Or reset motherbord settings to defaults you can reset with 2 methods.
Nov 11, 2009 | Asrock GE Pro-HT R3 Socket 478 Motherboard...
Asus motherboard( A7N266-VM)
FOr reset motherbord settings to defaults you can reset with 2 methods.
(2) Find jumper on motherbord named "Clear cmos" It has 1-2-3 pins.Put jumper in 2-3 position and thne power up then again put pin in 1-2 position thne all settings defaults.
Nov 11, 2009 | ASUS A7N266-VM Motherboard
My computer has been shutting down on its own the last two days. when i turn it back on the mb beeps a really long beep. the computer will run for only 5-10min before shutting down again. any ideas? i...
The long beed means you have refix RAM memory and processor.
For that open cpu cabinet and find motherbord.
Refix RAM memory on motherbord.
Open processor fan and processor.Then refix both.
Remove pci cards then refix it.
Make sure motherbord not ground with cabinet surface.
Then check.
Let me know if you need more assistance.Thanks.
Nov 06, 2009 | Soyo P4X400 Dragon Ultra Motherboard
Intel d845gvsr motherboard p4 processesor if computer is on then no display . so i see , don;t heat processor.
Remove PCI cards from motherbord.
Pull CMOS cell from motherbord for 15 minutes so all settings defaults.
Make sure your motherbord not ground with cabinet.
Then check.
If processor and circuit are heat high then put extra fan in cabinet.
Thanks.
Nov 03, 2009 | ASUS P5V800-MX Motherboard
HP Pavilion DV2000 no Display
First pull motherbord from cabinet some times motherboard is grounding with cabienet.
Then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reconnect ATX power connector to motherboard.
Then check.
If still same issue then open processor fan and processor then clean dust from all place in mothebord.
Then try.
If you still got same then something rong with your ram or motherbord.
Change ram then try.
Pull all card from PCI slot check motherbord only with RAM not even harddisk and other device.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
204 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
