Trying to view channel 28 uhf (single channel analog uhf modulator with Dish Network connected) on Olevia 532 B 12 LCD television. When slecting channel 28 I get a "channel not listed" message. When trying to auto program on the "air" tuner there is no response when pressing "Enter" on the remote hand unit. No luck after checking the "parental lock". HH Greggs in Indianapolis said that I need the firmware update for the tv to function correctly. Can you help???
  • larglass Feb 08, 2010
    As I understand it I only need to get a firmware update online, store it to my flashdrive and install it directly to the television via the USB port.
    This information was given to me via HH Greggs in Indy.
    According to them this is a known problem with this television and is easily repaired.
    I was told that I could get a firmware update for this "Olevia" television Model# 532 B 12.
    I should be able to send it to my flash drive and install it to the television via the USB port on the set.
    Where might I get the firmware upgrade?
  • 10,515 Answers
You could Download from :-
http://www.olevia.com.hk/lg_firmware.php
If you are the First Time User,, you need to Register.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 08, 2010
  • 5,138 Answers
Call Encompass Parts Distrubtion ask if they have replace board to update with give them your Make and Model number
1-800-638-3328
On olevia tv, channel scan will not pick up channels 3 to 13
i think the low band on your tuner has failed
Nov 16, 2014 | Olevia 332V LCD TV
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
My remote control only works for tv on & off and volume but not to change dish channel
I experienced this problem as well. I have a dual receiver and had issues turning channels on TV2; but counld easily access the volume. After reading the Dish manual, I learned that my TV1 and TV2 remotes connect through different signals (IR = infrared for TV1; and UHF= ultra-high frequency for TV2).
Check your remote to see if there is a UHF logo at the very bottom (under the Dish Network logo). The UHF remote sends ultra-high frequency radio signals to a UHF antenna which is connected to the back panel of the receiver. Make sure that you receiver is properly dusted and then check to make certain that the UHF antenna located on the back of the receiver is positioned straight-up. When the antenna is not correctly positioned it can cause problems with your remote signals.
Oct 06, 2010 | DISH Network IR Remote Control
I have a 1996 RCA 36" model # F35670mb and I am trying to get reception from a coax cable supplied by dish network, for a second room. I have connected the cable but I get no picture at all. Can you help?
You need to setup the dish receiver designating the channel for the second TV, typically a UHF channel like 21, then tune the TV to that channel.
Aug 12, 2010 | RCA Televison & Video
I have Dish Network and remote #1 and 2...the TV for Remote #2 has now changed but the remote will not work...I replaced it with an Olevia Flat Screen (used one) 32in LCDHDTV Model 432-S12 but cannot...
If this hasn't been resolved, I do have some steps that will help you out. The link below will walk you through a power scan, which will program the remote to the tv. At that point, you will be able to change the channels on the tv with the remote.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
Becki Barned
DISH Network Customer Service
Jul 14, 2010 | Olevia LT37HVS 37 in. LCD HDTV
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I just installed 2 rca converter boxes. I can't get the local UHF channel 28 on either one. Why?
Digital converter boxes without an analog pass through, block all analog channels.
Jun 27, 2008 | RCA Televison & Video
Adding new channel to menu
some sets are hard headed and wont take a channle number unless it is autoprogrammed, might try autoprogramming set to see if picks up ch 60, good luck! :-)
Jul 08, 2007 | Olevia LT27HVX 27 in. LCD Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
