Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
The lens will not retract or it will not take pictures. I can view the pictures already on the memory.
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Feb 08, 2010
Hi, re Olympus U840 my lens won't retract and I am hearing a musical sound from my camera. It won't take pictures, but I can review pictures already taken...is it fixable? Thnaks, Mark.
If the camera was dropped and cannot take pictures, then it is in need of professional repair, I believe.
Reviewing pictures already taken means that the memory and display on the back are ok. But, taking pictures involves mechanical issues that have been compromised, unfortunately.
http://www.olympusamerica.com/cpg_section/cpg_servicerepair.asp
Dec 25, 2010 | Olympus Cameras
When I turn my Sony DSC-W55 on it will say Access on the lens. The lens will come out and retract a couple times. It will beep and then say Turn the power off and on again. I have tried replacing the...
I had the same problem with the lens, just pull the lens gently until u hear a small click sound, it will be like new again. just tried it and it really works
Apr 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens will not retract
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Aug 03, 2008 | Fuji FinePix F20 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
I have a Canon Powershot S3 IS and I was looking at picture I had taken and the lens was retracted. I switched to the camera mode and the lens started to come out and hit my leg and stopped half way. The...
format ur memory card ....and replace the cells.....might work...contact the customer care for help ..they mightr be able to fix it ...
May 03, 2008 | Cameras
Kodak EasyShare C533
When I turn on the camera. the lens will not extend. The screen
will not show anything but a message, " date & time are already
programmed". No menu item works. Pictures cannot be taken.
Apr 21, 2008 | Kodak EasyShare C663 Digital Camera
Camera lens
My camera did the same thing. Try doing a couple of things.
1) remove and digital media cards.
2) turn the camera on and delete any pictures that may be stored in the camera memory (not on a removeable card)
3) remove the batteries for 60 seconds
4) replace the batteries without the media card and lay the camera on a flat surface with the lens pointing up (not sure if this helps, but it worked for me)
5) The lens should retract.
6) Turn off the camera
7) replace the media card and turn on.
I think for some reason my camera was getting hung up on the pictures stored in the camera's memory.
Nov 16, 2007 | Cameras
Lens doesn't retract when cover hits it. Only way to get lens to retract is to take out battery, put it back in, and then the lens slooooowly retracts, but will bounce back out if cover is closed...
The original problem was a camera with jammed lens mechanism or faulty lens motor. I think the camera had been replaced.
The following post is directed to new users following up on this thread, as the original problem had already been sorted:
Sep 12, 2007 | Olympus Stylus 400 Digital Camera
Camera powers on like it is going to take a pic then lens retracts
On my EX-Z750 there are two buttons on the top rear, one a right-facing green arrow with a green box around it, the other a red camera icon. If you turn on the camera and accidentally hit the green arrow button you will only be able to review the shots already on the camera. To return to taking pictures, push the red camera icon button.
Aug 23, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
