Question about HP LaserJet 1020 Printer
It doesn't print. It's been working properly all morning and then suddenly nothing. What can I do?
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Turned microwave on this morning ,sudden crackle,then nothing.
Sounds like something has shorted out-blown. Unless it is a very expensive model it won't be worth fixing and is not something you should attempt yourself anyway. If under guarantee then get it repaired via the guarantee arrangements. No harm in checking the plug is wired properly but as the light and timer are working it is very doubtful it is a connection problem. I think you need to buy a new microwave!
Oct 03, 2009 | Electrolux EMS2487X Convection Microwave...
My HP 7350 Prints Almost Nothing
You should try going into the properties and running the head cleaning that will fix ya right up
Aug 27, 2009 | HP PhotoSmart 7350 InkJet Printer
HP laserjet 4L wont print from computer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | HP LaserJet 4L Printer
Canon i850 seems to be printing, but get only blank page
try cleaning the nossle of the cartridge , if that too doesnt work try cleaning the contacts of the cartridge holder, if that too doesnt work then take the printer to service center
Dec 19, 2008 | Canon i850 InkJet Photo Printer
Panafax UF 885 resets itself when trying to print comm journal
sounds like your firmware might be shot and it needs to be reinstalled, if your in canada i can recomend a tech
Nov 03, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Printer won't print
I've had this 6110xi all-in-one for a few years now. Everytime I have the "no-printing" issue I need to unplug the printer, and leave it unplugged overnight. The problem magically goes away in the morning.
I've installed the printer on a separate computer while it was having a "no-printing" episode and still couldn't print there either. So it sounds like there's something funky with the printer internal cache requiring a long power-down.
Dec 03, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP LaserJet 1020 Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
