Question about Waring Pro WC1000 Coffee Maker
We have A Waring Pro coffee maker. We have always
We have A Waring Pro coffee maker. We have always had problems with coffee grounds in the brewed pot after brewing decaf, however it is now happening with regular coffee as well. Any ideas on what would cause this
    Problem Solver:
  • 9 Answers
Use properly and wisely the coffee maker
Posted on Feb 08, 2010
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
We have a waring pro wc1000 coffee maker and it just started taking forever to brew a pot of coffee. How can we fix it?
If you've never done a decalcification, do one. A decalcification basically means that you're running vinegar and water through your coffee maker to get rid of calcium build up, which can cause your coffee maker to run very slowly, or not at all.
You always want to do a "1/3 white vineger to 2/3 water" solution--meaning that if you have a 10 cup coffee maker, you want to fill it 1/3 of the way up with vinegar (3 cups), the rest with water. If you have a 12 cup coffee maker, you want to do 4 cups of vinegar, fill it the rest with water. And yes, it DOES have to be white vinegar--the other vinegar types don't do anything for calcium ;)
You basically just brew the vinegar/water though your coffee maker, and you might have to do it 2-3 times before it will be completely fixed--most companies recommend that you run the vinegar/water through your coffee maker once ever 1 to 2 months to prevent things like this from happening, so if it's already happening, you may have to do it more.
And always remember--after you brew a pot of vinegar/water through your coffee maker, brew a regular pot of plain water through it afterwards, or your coffee will taste like vinegar! lol
If all else fails, you can always contact Waring customer support - their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 26, 2009 | Waring Pro WC1000 Coffee Maker
I lost the instructions for using the Waring WC1000 coffee maker-how do I brew a pot of coffee?
JUST LOOK UP ONLINE THE MODEL NUMBER OR CONTACT CUSTOMER SERVICE FOR WARING AT http://www.waringproducts.com/
Aug 22, 2009 | Waring Pro WC1000 Coffee Maker
Waring Pro Coffee Maker has a water flow problem
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
May 21, 2009 | Waring Pro® WC1000
I have a waring pro 12 cup coffee maker but no manuel.
Most of them will make any amount of water you put in.But I would remen 2 to 4 cups.
Mar 13, 2009 | Waring Pro WC1000 Coffee Maker
Waring pro wc1000
Try plugging it into another GFI outlet. If it still trips, it's a problem with the coffee maker wiring and is cheaper to replace it than fit it.
Aug 25, 2008 | Waring Pro WC1000 Coffee Maker
A short condition has severed a conductor wire inside the coffee maker. Seems to be a common problem with coffee makers as the wires are in close proximity to heating devices.
Mar 16, 2008 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
LEAKING WATER
I had the same with a Saeco it was caused by a leaky boiler, after replacement, it was fine...
Aug 08, 2006 | Waring Pro WC1000 Coffee Maker
Waring Pro WC1000 Coffee Maker Logo
216 people viewed this question
Top Waring Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Waring Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
