Question about Sony Cyber-Shot DSC-P73 Digital Camera
Camera turns on only in playback mode
My camera turns on in playback mode but shuts down in any other mode.
Have tried pushing reset and have fresh batteries installed.
Is my camera dead?
  • 3 more comments
  • Scherlac Apr 01, 2008
    Hello, I have the same problem, settings ok, play back ok, but after lens
    opens power of the camera go's down.
    Some times, if I switch off the display at play back, I can turn it on.
    (less then 2 times after circa 30 try).
    How can I update the cameras firmware?
  • Anonymous Apr 07, 2008
    I have had mine for two years now, and it just started doing the same thing. The batteries are not dead, because it will turn on in review/playback mode, but as soon as you switch to picture-taking mode, it shuts off. I really loved this camera, took excellent care of it, but this is the second Sony I have had and each has only lasted two years before developing a serious problem. I'm seriously considering switching brands.
  • ss7980 Apr 09, 2008
    I have the exact same problem. PLEASE PLEASE HELP ME...
  • davidpl May 01, 2008
    my cam worked well for over three years. today i attached the cam (with full memory card) to pc and watched some pictures (from the cam, not after uploading them) on the pc. i also rotated the pictures and when going to 'next' the pc 'saved' automatically. afterwards i 'safely removed hardware', plugged out the usb cable and i noticed a blue screen on my cam, saying 'file error'. i shut the cam down, and turned it on again. it said 'file error' again and then shut down again. now, every time i try to switch the cam on, she shuts down immediately, the green 'power' led just lights up for a short moment....
  • maheshsshah May 11, 2008
    My Camera swithces on Only in "Set Up Mode" and "Preview Mode" . For all other modes it does not get activated. I have put the NEW battries and cleaned the contact points of battries as well. Still have same probmem
    -- Mahesh Shah
Sanurulz, thank you for your help, but it is ok already.
the next day, the cam suddenly stayed 'on' when i put it on, and i was able to remove all photos with a file error. i guess the pc tried to save the rotated pictures, but that did not work...
Posted on May 09, 2008
  • 684 Answers
Davidpl i think there is a problem with the memory card try using a diffrent memory card and it will work fine
Posted on May 08, 2008
Why does camera shut down?
Your batteries are no good! Digital cameras need a good amount of current to operate and when they are not fed properly they will just shut down!
Nov 24, 2015 | Panasonic Lumix DMC-LX2 Digital Camera
Camera won't trun on or charge.
Follow this procedure to troubleshoot if the power will not turn on.
Ensure you are using fresh or fully charged batteries. Check if the battery using is NPBG1 (supplied)
  1. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  2. Attempt to turn on the camera.
  3. If the issue is not resolved, try replacing or recharging the batteries if available.
  4. Attempt to turn on the camera in Playback/Edit mode by moving the mode switch to the Playback/Edit mode or by pressing the playback button.
  5. Switch the unit to camera mode and attempt to turn on the camera.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. (Skip this step if the camera being used does not support the use of an A/C adaptor.)
  7. Attempt to turn on the camera.
  8. Try power resetting the Camera. (Remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the battery after 1 minute and check if the Camera works normally.)
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. If you're located in the U.S, online repair request can be created for getting the unit serviced at the Factory service center by clicking the link below: https://eservice.sony.com or else by selecting your country from Sony Global webpage.
Jul 25, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
My sony digital cam wont turn on or remain on. please help me. tell me what i should do
  1. Ensure you are using fresh or fully charged batteries. IMPORTANT: Batteries discharge more quickly when used in cold weather conditions.
  6. If the issue is not resolved, try connecting the AC power adapter to the camera and a working electrical outlet. NOTE: Skip this step if the camera being used does not support the use of an A/C adaptor.
  8. Remove the Battery, press the power button for 30 seconds.
  9. Please wait for one minute, insert the Battery and turn it on.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. [[]]
Jun 25, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
My fuji A700 shuts off when trying to take a picture! It will not hold any charge
Certain A700 has a "known error" which displays low
batteri warning when using playback mode.
The camera shuts off even if batteries are fresh.
A firmware update will fix that. This is however not a do-it-yourselves update, but needs to be done in the service center. It's FOC in most regions, but you should contact you local distributor to check this.
Jan 13, 2010 | Fuji FinePix A700 Digital Camera
Zoom
Hey bello205,
This camera does not allow the user to actually turn off the optical zoom, but does allow the user to shut off the digital zoom. If you are talking about the digital zoom make sure it is turned on in through the menu system. As far as the optical zoom goes make sure you are not in playback mode. If this doesn't work you can try having the camera reset to the original settings every time you shut off the camera by choosing this option under the setup menu in playback mode. If none of this works have the camera looked at by an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
May 01, 2008 | Olympus Camedia C-720 Ultra Zoom Digital...
Error Code EO3 System in Safeguard Mode
Defective mechanism, 03 error states that a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera.
Aug 16, 2007 | JVC 580136 Camcorder
Can't take picture
Needs to go back to Panasonic- an inherent fault.
Aug 16, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
After 2 years, erratic behavior.
Lens unit problem. Either imact or sand etc in the lens zooming gearbox area. Maybe uneconomical to repair on this model if new lens unit has to be installed. ( it is shutting off because the lens does not come on line properly and so the shutter and CCD do not come on line... when this happens camera switches off. )
Aug 04, 2007 | Fuji FinePix S3100 Digital Camera
Camera freezes in any picture taking mode
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Dec 28, 2006 | Gateway DC-T50 Digital Camera
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-Shot DSC-P73 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
