Question about Lexmark X5150 All-In-One InkJet Printer
X5490 says left cartridge incorrect. This is
X5490 says left cartridge incorrect. This is black cartridge which has been in machine for months! Have jsut replaced colour cartridge with Morrisssons compatible and message says unsupported cartridge. Any suggestions?
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Keeps saying my colour cartridge is missing
Problem
Wrong cartridge; Left cartridge incorrect; Right cartridge incorrect; Left cartridge missing; Right cartridge missing; Error 1205; Error 1206; Cartridge error; Cartridge incorrect; Cartridge missing
Environment
Microsoft Windows XP; Microsoft Windows XP Professional x64 Edition; Microsoft Windows 2000; Microsoft Windows Vista
Solution
Explanation
An 'incorrect cartridge' or 'missing cartridge' error can be displayed if:
    • The wrong cartridge is installed, or
    • The cartridge is not installed properly, or
    • The cartridge is missing.
What to do
X4850
http://support.lexmark.com/index?page=content&id=SO4738&segment=SUPPORTproductCode%3D&productCode=LEXMARK_X4875&locale=EN&userlocale=EN_US
Feb 12, 2018 | Lexmark X5270 All-In-One InkJet Printer
Is it a factory new cartridge, or was it refilled somewhere?
It's more likely to be bad if it's a refill. If it wasn't the Lexmark label on the box, it's a refill.
Put the old one back in to see if you get the same error. If you get no error, your new cartridge is bad, get a replacement.
May 31, 2012 | Lexmark X5495 All-In-One Fax...
I replaced a lexmark x4650 black ink cartridge #36 with another lexmark #36. when I try to print I get an error message stating that the left cartridge(the one I replaced is incorrect). Any suggestions?
You might have put it in incorrectly. Sometimes it could be as simple as taking the cartridge out and putting it back head but make sure it is snapped in correctly. Also, you could try unplugging the machine, taking the cartridge out and then replacing it once the machine is on. That could work as well. If it doesn't let me know.
Jul 26, 2011 | Lexmark X4650 InkJet Printer
"LEFT CARTRIDGE INCORRECT" everything was ok
Re-seat the black cartridge and make sure it's properly inserted. If error continues, try to insert a different known working black cartridge to determine if the other is faulty.
Apr 26, 2011 | Lexmark X4650 InkJet Printer
Left ink cartridge incorrect. It is the right ink
A trick which may work is cleaning the contacts on both the cartridge and the printer.
Make sure you've switched it off first, I'd try gently buffing with a soft dry cloth first.
HP reccommend using distilled water and cotton buds, but not alcohol based cleaning fluids.
Allow the water to evaporate before replacing cartridge and switching on.
May 11, 2010 | Dell 946 All-In-One InkJet Printer
Newly installed Cartridge. Problem: "Left cartridge incorrect".
When you place the old cartidge does it give you this problem.try to clean the contacts on the printer and the cartridge it self.
May 03, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark x5490 Right /left cartridge incorrect
If you brought new cartridges and printer detecting it empty ,then you get it
replaced as the Lexmark cartridges comes with a 6 months warranty ..
Good luck....
Feb 13, 2009 | Lexmark X4530 InkJet Printer
Right cartridge incorrect" and "Left cartridge incorrect
Many newer HP Printers internally keep track of your cartridges by a serial number embedded into the cartridge. When it's low, the printer remembers. This is entirely done within the printer itself, and not the printer software. Some printers EXPIRE the cartridges after 18 months according to the installation date even it is not empty.
Outrageous, but true.
A fix? Most HP printers will only keep 2 cartridges in memory, so if you have 2 extra cartridges, (even empty ones) you could cycle them through to reset the printers memory, and reset the ink level to full. Basically, even though you've refilled your cartridge, the printers has the cartridge's serial number stored in memory. This will reset it.
Jun 02, 2008 | Dell 962 Photo All-In-One InkJet Printer
Black Ink Cartridge error
i ended up putting a color and black cartridge in and everything is fine.
Mar 27, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X5150 All-In-One InkJet Printer Logo
79 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
