THE DRUM ON MY WASHER DOES NOT SPIN AT ALL. STILL SOUNDS LIKE IT WANTS TO. WHEN I LOOKED UNDER THE DRUM THERE ARE TWO WHITE PLASTIC PIECES THAT APPEAR TO BE BROKEN.DO YOU HAVE ANY IDEA WHAT THIS MIGHT BE AND A BALLPARK ON COST?? THANKS!
    Sergeant:
  • 215 Answers
What make of Machine. Email me on archie4805@yahoo.co.uk and I will try helping you with this problem
Posted on Feb 08, 2010
During the spin cycle it sounds like the drum is about to come out of the machine and there are little grey plastic pieces in the clothing.
Sound like the basket has broken away from the spinning support coming of the back of inner drum, Gray plastic is the front ring the inner tub is now rubbing on. This has been making noise for a while. Phil 1-800-559-1411 www.phils.com any help I can give you.
Aug 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
While washing heavy load (towels) spin cycle became very loud and sounded out of balance. After cycle finished, noticed several small pieces of white material. Washed a light-weight load next; same loud...
I had exactly the same problem, sound and everything. I just pulled the front off the washer and discovered that I half mooned shaped, big hunk of concrete was broken in half and hanging down rubbing who knows what. I'm sure it's just a weight to help make it stable while spinning. I don't know if the broken concrete is a result of another problem or not. I'm going to try to find a replacement and install it myself and see if it's fixed. I can just hope.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer dryer 4 years old. Dryer has no heat. Washer will not spin, drum just moves slighly from side to side,
probably a physical problem of your metal lip spinning onto the plastic white rim which probably deteriorated into small plastic pieces you werent aware was your plastic rim liner
Sep 07, 2010 | Whirlpool Washing Machines
The drum of my washer does not spin freely. When I manually spin the drum, I found myself having to push it along to turn on one side. Also I found pieces of white plastic on my laundry? Please advise...
This drum is driven by motor which is coupled with a belt that connects the drum and the motor,the is a possibility of a broken belt,or the motor is stack, may be the motor is not receiving power for the motor to be driven to drive the drum.
To access this you need to open the screws at the back of the washer,the plastic pieces is a sign of some broken parts in the washer,if you find that it's the belt that slept off the puller place it back and test but unplug the washer from power before doing all this.
May 18, 2010 | Whirlpool GHW9100L Front Load Washer
During the spin cycle basket vibrates very badly - very rough
I had a similar problem. During the final high spin and there was POW and the drum went funky eating into the plastic. I opened the back of the washer and look things over,.The belt for spinning was intact. I set the washer on a drain/spin option and watched from the front and back. While watching the pulley on the drum and could tell there was a hiccup as it went around. I pulled the pulley off and put on a new pulley. The new pulley was going in a perfect circle to spin the drum. It's not a hard repair, just need a little muscle to loosen the nut holding the pulley on and the same muscle to tighten the nut as much as possible. Hope this helps.
Nov 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont work
If the motor is running but no agitation or spin is happening, then most likely the coupling between motor and gearbox has gone- look for black sooty deposits under your washer as proof. There may also be one or more pieces of white plastic. This coupling usually goes if the washer is overloaded regularly.
Dec 29, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My front load kenmore elite 110.45872 shakes during spin cycle
your basket shaft is broken or the bearing are bad it probably sounds like a freight train when it goes into high spin you need your washer rebuilt but it would be cheaper to buy a new washer. to rebuild the washer it will cost aleast 800 dollars
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
White Plastic From Washer
Sounds like pieces of the detergent drawer might have cracked and fallen off. Check the drawer and see if you need to replace it.
Nov 01, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
