Question about HP OfficeJet D135 All-In-One InkJet Printer
HP D135 Wont Print IN COLOR!
My printer is connected via local network, and everyone in my office except for me is able to use this as a color printer! I have tried downloading the current drivers directly to my computer and installing the CD onto my computer but NOTHING works. It only prints black and white!!!! AHHH! HELP
  • Dacy Feb 22, 2008
    it doesn't say anywhere in properties that it is set to print to in anything, there is not option to change it from grayscale to color
    it does say under general: features: color: NO
    Genius:
  • 1,601 Answers
Dacy, Go into the printer properties and check and see if it is set to print in grayscale.
Please let me know!!!
thanks
Posted on Feb 22, 2008
  • Thomas Christopher
    Thomas Christopher Feb 22, 2008
    can you change it?
  • daisydove12 Apr 20, 2011
    I have the same problem too. please help?
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Prints gibberish when a multi-page color document is printed
This could be a driver issue. Without knowing exactly how your printer is connected to the network I'm making a rough guess here.
There is a Universal HP Printer driver that could be tried as well as the PCL5, PCL6 and Post Script drivers.
I've had issues with the PCL6 drivers before doing this and I usually install the PCL5 drivers instead.
Jun 21, 2009 | HP 4700N Color Q7492AABA Laser Printer
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
May 03, 2009 | HP OfficeJet D135 All-In-One InkJet...
Hp officejet d135
You can't, all carts must have ink in them
Feb 16, 2009 | HP OfficeJet D135 All-In-One InkJet...
Network or Share HP LaserJet 2200D Printer
Try this:
1. Go to the computer where the printer is attached or connected. Go to Printer and Faxes under XP, right click on your printer icon, then click on share. On the same computer, click on Start then click on run. Type in cmd then click on OK. On the black window or command prompt, type in ipconfig then press enter. Take note of the IP address.
2. Go to a computer that you want to print on the printer. Click on start then click on run. type in \\IP address of the computer where the printer is attached. For example: On the run box type in \\192.168.1.2 the click on OK. You will see there a window and you can see there the printer that is attached to that computer. Just right click on it then click on Connect.
3. Try to print.
Hope it helps!
Oct 21, 2008 | HP LaserJet 2200D Printer
Won't print in color
Is the color cartridge new and do you know how to check the gauge in your control panel for the ink levels?
Jun 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
HP d135
Clean the copper contacts of the ink cartridge and the printhead wih the cotton swab and then try. Moreover in the printer there is an option to clean the printheads and ink carts. Later ty to print the h/w test page from the printer, if it prints fine then in the computer, righth click the printer icon and left click properties,in the color settings check if there is an option print in grayscale ... if thatoption is checked then uncheck the option.. and then print the test apge from the computer. If while priting the h/w test page it does not print in color then either upgrade the printer or replace the printer as the contacts of the printer ink carts slot are corrupted.
Jan 22, 2008 | HP OfficeJet D135 All-In-One InkJet...
4600n
Can't come to VA but will the printer print a test page from the pannel?? Check the net card setup. Is it a shared local printer and set to work ofline?
Aug 23, 2007 | HP LaserJet 4600dn Color Printer
HP OfficeJet D135 All-In-One InkJet Printer Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
