Question about Sony Playstation 3 (PS3) Console
Used my hdmi cable on my other tv perfect,pluged it back to my old tv and it dont work why ? ps3 im on about
    Guru:
  • 111 Answers
F you attached your PS3 to an HDMI capable TVit asks you if you want to switch to HD Mode.
However, once you attach it back to a regular TV you get no picture.
Follow these steps to resolve:
1. Turn off the PS3 so it only shows a red light. You can flick the power switch in the back then back on again.
2. With your PS3 connected to the TV and the TV on, press and hold the power button.
3. Hold the power button until the screen "flickers" and then immediately release.
4. Wait a few seconds and the PS3 logo should appear.
Posted on Feb 09, 2010
Hdmi
Which TV do you have? Hopefully then we can help. :)
Sep 01, 2007 | Sony Playstation 3 (PS3) Console
I can not see any picture or sound at all. We have the HDMI cable pluged in the PS3 and the TV, but red white ,and yellow plugs we r not sure where they should be.
There are different settings for PS3 video output, i.e. if it is set for HDMI it wont display when a scart lead is used. Try the scart connector, if it works go into settings and change to how you want it set, dont forget to save settings
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
I have a new ps3 slimline,cant get a connection t my samsung HDTV
What you need to do is use a different tv or scart/av cable first, go to settings and reduce the resolution its because the tv cannot handle such a high res, if this dosent work, please post back, Regards
Dec 25, 2009 | Sony Playstation 3 (PS3) Console
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Sep 14, 2009 | Sharp Televison & Video
PS3 doesn't work with tv anymore
did you move the ps3 while it was on. If you did the reset for AV should repair both the AV problem and your HDMI as well. Shoot me a message back if it works or doesn't.
Thx
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Cascading white craziness
First thing you should try is using the regular old AV cables. That way we know if it's an hdmi problem or a video problem with the PS3. Hook them up, do the manual video reset ( hold down the power button until you hear a second beep, quickly release) and then post back here with the results.
May 11, 2009 | Sony Playstation 3 (PS3) Console
No sound from ps3 to home cinema via an optical cable
If you have not run the set up you will need to, however I'm guessing you did because you would have had to make some changes to the settings to get the image to come up on the screen but without being physically at your location I can just guess.
In order to view your PS3 in full 1080p you need the HDMI cable which you already have. If you have not gone into your video settings then you are not viewing via the HDMI cable and you will need to to get things working right.
In order to view via the HDMI cable you would have had to had both the standard PS3 interface cable that comes in the box (the one that goes from the PS3 to your tv with the composite video (yellow) and the left and right audio (red and white) and the HDMI cable pluged into your PS3 and your tv at the same time. then you turn on the PS3 making sure your TV was set to whatever imput the composite and left/right audio is pluged into (typically VIDEO 1,2,3 ect.) and enter the menu, go to the settings and then down to your display settings and change it to HDMI, the image should then leave the screen (because it switched to HDMI) you will need to have your TV remote handy for this because you will need to switch sources on your tv to HDMI 1,2,3 ect, which ever one you have it pluged into. When you have switched to the right HDMI imput there should be an on the screen that is counting down and asking you if you want to accept the changes. Select yes and Move on through the settings selecting the maximum resolution your tv is capeable of
720, 1080i, 1080p) which can be found on the box the tv came in or somewhere on the tv or manual. While running this settings change it should ask you the audio source you are using make sure you select Digital Optical and that it is pluged in to you PS3 and your reciever. Once this is all done you can remeove the standard PS3 hook up that came with the box and put it away you wont need it any more, unless you move the PS3 around and the tv you move it to does not have HDMI in which case you will have to change the settings before you move it back to the standard cable or you will not be able to see it displayed on the tv sceen you move to and it will be impossible to run the settings.
If you have already done that and just want to verify that your source for audio originating from the PS3 is digital optical you can check that in the same settings menu under audio settings. Then make sure the reciver is on and set to whatever imput you have the cable pluged into and you should be good to go.
If all that I have described has been done already then the audio cable could be bad or the problem lies internaly with the PS3 or the reciever.
Good Luck hope this helps
Oct 04, 2008 | Sony Playstation 3 (PS3) Console
PS3 HDMI output problems
Thanks it works,I have a vizio and did the steps.
May 04, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
