Question about Ovens
GE oven varistor board
I recently got a new (in packaging even) but ancient 1985 GE JKP77G*02 microwave/oven combo for almost nothing.
Hooked power to test before installing, it came on, then a loud pop, spark, smoke.
I am no tech but looked and determined the varistor board ge (discontinued) part number wb27x5293 is fried
AND that this probably happened because my white and or neutral power connections came loose- so it may not be the ancient oven's fault
questions: any idea where to find this part and if I find it/ replace, what is the chance no other damage was done? I have very little invested so far but don't plan on putting much money into an oven this old, a little time/effort no problem
  • 25 Answers
Try calling a-1 stove hospital 323-751-2225, they do rebuilds on parts may be able to help you
Posted on Feb 23, 2008
Model WOC54E whirlpool microwave/oven combo. recent power outage. microwave works fine. oven display says feature not available for baking when bake button pushed
Hello Carla Christian,
The problem with "power outages" isn't the
out part... it is the VOLTAGE VARIANTS...
Will cause a weak spot to fail... Poor sold joint
or
a transformer... but since you have PARTIAL
functionality you need to look to the specific
are of function that is DEFECTIVE...
I tried you part number but my
parts house wants more numbers...
Take a loo at what I found...
This site also has technical support... AND
VIDEO guides...
They can help you get your WHOLE model number.
http://www.appliancepartspros.com/whirlpool-wide-interface-board-wpw10412514-ap6021091.html
Carnac the Magnificent
May 31, 2017 | Whirlpool Ovens
I have an ancient Sharp Carousel Alacard microwave. Part of the door seal has fallen off and broke into pieces when it hit the floor. Can we still get these parts or should I get a new microwave
Ancient is the key here, do you want to keep it sentimentally or build a new relationship with a new , young better model? The seal is essential to keep users safe from radiation....do not use if seal is damaged. Microwave is a klystron type transmitter used in radar. Have repaired and ck for escaping rf energy.if you go that route.I'd go new.
May 13, 2017 | Sharp Ovens
GE Dualwave Mirco Oven combo - Oven works fine - Micro doesn't even show the clock
There is a very good chance that it has blown a fuse. They would be located behind the control panel. Be careful around the wiring to the high voltage circuit and make sure that the power is shut off.
Apr 14, 2014 | GE Jkp90Dpbb 27" Built-In Combo Microwave...
GE wall oven/micro combo JKP86WF7WW will no longer heat
Is it the oven or the microwave that is not heating? If it is the oven it is a very good possibility that the common relay on the control board has gone out. I have seen this several times on GEs. Unfortunately the control board will need to be replaced or repaired. Corecentricsolutions.com is very good about repairing control boards. the bad thing is you have to send them the board. Mark all connections before removing the board. (power off of course)
Feb 14, 2014 | Ovens
Wall microwave worth fixing?
There's micro switches and fuses worth fixing on microwaves... if its doing nothing its most likely the fuse on control board. maybe even the breaker.
Sep 01, 2012 | Ovens
I own a wall oven/microwave combo, GE JKP76 and JKP77. I recently turned on the Autoclean function however, once completed the door remains locked and there is an error message flashing "F2" and...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Mar 05, 2011 | GE JKP15 Electric Single Oven
Brand new GE Profile oven/microwave combination just delivered and the carousel in the microwave will not spin.
is all the packaging removed? sometimes a tiny piece of styrofoam or tape is holding in place
Sep 03, 2009 | GE Ovens
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
Mar 16, 2009 | GE JTP15 Electric Single Oven
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
Ovens Logo
212 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
