Question about KitchenAid KGRT607 Gas Kitchen Range
Rear Panel Can the rear panel that rises above the cooking surface be removed from this stove to allow it to be used in an island with a retractable vent system. Brian blaurence@gmail.com
    President:
  • KitchenAid Master
  • 2,651 Answers
Generally not
Posted on Feb 23, 2008
My Cooker is coming up with a E3 What do this means or how to fix it?
Error Code Error Solution
F0 An internal error was detected. Disconnect power. Wait 5 seconds before reconnecting power. If the symbol appears again, call for service.
F2 The surface cooking area is too hot and has turned off. Remove the pans from the surface cooking area. "F2" will disappear when the surface cooking area has cooled. If you turn the surface cooking area back on and "F2" reappears, the cooktop is still too hot. Turn off the surface cooking area and allow it to cool.
F4 The pot or pan is too close to the control panel. Make sure the pot or pan is centered on the surface cooking area and nothing hot is on the touch control panel. Wait 5 minutes for the control panel to clear. If "F4" appears after turning the surface cooking area back on, call for service.
F8 The surface cooking area has been in operation too long. The surface cooking area automatic shutoff was activated. Turn off the surface cooking area.
C1 The power voltage is too low. Turn off the cooktop. Wait 5 seconds, then turn it back on. If this continues, contact a qualified electrician.
C2/C3 The cooking surface area has overheated. The surface cooking area automatic shutoff was activated. Wait 5 minutes for it to cool, and then turn it back on.
Jan 26, 2017 | Washing Machines
Remove drum on a gibson GDE546RBS1 dryer
Remove the rear louvered panel on the lower left, make note of how the belt is routed around the motor, and tension pulley, also note which direction the belt grooves are facing, remove the belt by applying pressure to the tension pulley against the spring, the belt will come off, allow the pulley to gently retract back releasing pressure on the spring. Use a rigid puddy knife and insert in the front crack under the main top on the front approx 2 - 3" in from each corner gently pushing against each spring lock while simultaneously lifting each corner of the top, the main top then just lifts up, is hinged at the rear, and can rest against the back wall. There are probably 2 Phillips screws holding the front panel on at the top left and right, and usually 2 hook clips on the bottom. remove the top screws, disconnect the door switch and lift the panel up. The drum has a round ball bearing looking knucke on the rear, you will need to lift the rear of the drum up and out of it's socket.
Knuckle with nylon socket.
Apr 16, 2014 | Dryers
None of the elements work, stove top or oven, stovetop light 'surface heating' will come on but nothing heats. Oven light on panel doesn't turn on but light in oven is off unless both dials are on or a...
Remove the panel on the top of the back of the stove - check for grease residue on connectors plugged into circuit board - clean connectors and circuit board with electrical contact cleaner - reassemble and test for correct operation. The oven vent at the rear of stove sometimes leaks grease filled vapors into the area of the control circuit board.causing bad or intermittent electrical connections to oven temp sensors and front controls on the oven.
Dec 22, 2017 | Kitchen Ranges
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
Mar 11, 2010 | Stoves 720EF Electric Double Oven
How do you remove the cook top on a GE profile model number JSP47SOH2SS
take off the knobs, unscrew the plastic underneath the knobs, take off the plastic cover. unscrew the four metal screws holding the the display panel on. remove the 5 silver screws across the top inside of the plastic cover front and the 2 black ones on the lower left and right sides. remove the to stainless steal stews on the sides of the stove towards the rear top. these should allow you to remove the cover once you unplug the two cables going into the burners.
Feb 26, 2010 | GE Cooktops
XLR cables will no come out.
Most XLR cables have a small catch that needs to be depressed to allow removal of the XLR connector. This catch is close to the surface of the rear panel. The catch is either on the socket (on rear panel) or the plug (lead) and is usually depressed to enable removal.
If this is not your problem please advise>
Feb 09, 2010 | Yamaha P-7000 2-Channel Amplifier
After self cleaning cycle, oven door will not open. the lever won't move.
in the rear of the stove there might be a wax motor that has melted not allowing the stove to be unlocked. or a stuck switch.
all too common with self clean ranges.
unplug stove, remove rear panel and begon looking for any type of heat damage, or any switches that may have been stuck closed.
i see this at least once per week
Oct 09, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire stove mod #cfef385jht1
I'M NOT TO UP TO PAR ON THIS MODEL BUT SEE IF THERE IS A PANEL ON THE REAR OF THE CONTROL PANEL AND LOOK FOR A FUSE
Aug 25, 2009 | Frigidaire FEF366EC 30" Freestanding...
Microwave above the stove
Yes there is a code. The code is 18" from the cooking surface to the bottom of the microwave. At least that is the code in California. There is no code to the top though.just the bottom.
Good Luck and Please Rate FixYa!
Jan 09, 2009 | GE Monogram ZV1050SFSS 42" Island Chimney...
When using the oven or especialy the broiler the outside of the stove (the part where the control panel is), right above the burner gets extremey hot so hot if you would touch it you would get a severe...
There is a vent pipe for the oven in the back usually just under the left rear burner, it is normal too get hot air there, if your drip pans are all solid you might want too change too pans that have holes in the center it should allow the top too breath a little better.
Jul 30, 2008 | Maytag Kitchen Ranges
KitchenAid KGRT607 Gas Kitchen Range Logo
65 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
