Bush MTT1 turntable - does it contain a pre-amp?
    Brigadier General:
  • 8,546 Answers
Yes, according to someone else online who owns one:
"It is a simple device (I have one)
33 or 45 rpm
Pre-amp on/off switch underneath.
Two leads out.
Arm up/down lever and slight speed control.
When the light are stationary due to strobe effect then the speed is right."
Posted on Feb 08, 2010
Do I need a pre-amp?
Hi, no built in pre amp. If you are connecting to an amp without dedicated phono input you will need to use a preamp or mixer. Cheers John.
Apr 25, 2013 | Stanton STR8-30 Turntable
Music hall mmf 2 not working with pre amp
The pre-amp has failed. Since you can hear the signal with the deck plugged into the amp that proves the cartridge and deck are working.
Apr 20, 2013 | Music Hall MMF-2.1 Turntable
Can I connect a turntable to my Sony mhc nx3av system which I got 12/13 years ago and it is great. Will it be accessed via the MD option? And must I get a turntable with a pre-amp? Thanks in...
YES, you can not only connect a turntable but also a VCR or DVD player or other analog audio sources using either of the top two RCA INPUT jacks on your unit. Now, for a turntable, you will need to buy a pre-amp because typically a turntable provides too low a signal level for most components to handle. These pre-amps cost $35 and up. Most turntables do not provide a pre-amp. Usually an amplifier or receiver will contain the pre-amp and have PHONO inputs specifically for a turntable. So you are correct, you need a pre-amp of some kind. Be sure to select the inputs on your Sony where you connected the turntable when you want to play records. Hope this helps.
Mar 14, 2011 | Audio Players & Recorders
I have Bush MTT1 mini turntable and power, but no speakers. It says it has a built in equalized amplifier so can be connected to a music system. I have no music system. There is a split ead with red and...
You are mistaking the built in amp for a power amp. The built in amp only makes the deck loud enough when connected to a power amp. The Red and White cable are the Right (RED) and Left (WHITE) channels. There should also be some earth connections too. You need to get a power amp or system that has tape or aux connections. You can then get two phono plugs from your local dealer (only cheap) and solder the wires to the plugs. Main wire, to the main part of the plug and one of the earths to the body of the plug.
You can then plug them into the amp or system and that will then play.
Nov 10, 2017 | Audio Players & Recorders
Major feedback hum from speakers
The reason for the hum is as follows:
1) The phono input on the receiver contains an additional stage of amplification required for typical turntables.
2) Pluggin in a unit that has a signal level too high will generate this hum.
3) Your turntable contains an pre-amp that allows it to work using an aux input (or tape input) as most receivers today no longer have phono inputs.
4) Grounding issues relate to the older types of turntables where there was NO pre-amp stage inside the turntable. In this case ,the signal levels were so low that stray noise would often get in the way of the signal. Proper grounding would elimiate this noise.
Hope this helps.
Dan
Aug 10, 2009 | Sony PS-LX250 Turntable
I am trying to hook together a computer and a turntable(Turntable has its own pre-amp) & I need a diagram on what wire gos where?
OK. Since there is a pre-amp, all you need to do is to connect pre-amp output to Line-in input on the PC. This may be a bit of challenge as the connector on the pre-amp and computer are of different types. Usually, you need a cable with RCA connectors on one end and 3.5mm stereo pin (same pin as you have for stereo headphones) on the other.
Aug 17, 2008 | Sony PS-LX250 Turntable
Connecting a turn table to a micro stereo system
You will need the following to connect this to that system:
1) Phono Pre-amp
2) 3.5mm to RCA adapter or 3.5mm 'Y' cable to RCA
3) Turntable
Your turntable will connect to the Phono Pre-Amp input. This pre-amp will also have an output. This output is RCA, from here you connect to your system using the 3.5mm adapter or cable.
That's it.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
Aug 07, 2008 | Audio Players & Recorders
Turntable connection
Yes, you'll need to purchase a PHONO PRE-AMP, and then connect the turntable to the pre-amp, and the pre-amp to the LINE INPUT of your receiver.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
May 20, 2008 | Yamaha RX-V361 Home Theater Receiver
344 people viewed this question
 Grubhead
Grubhead
