Question about MSI K8MM-V Motherboard
MSI K8MM-V - Usb on the front case work like usb1 and not usb2.
Usb front case work like usb1 and not usb2. I connected the cable from motherbord to the front panel, but when I connect a pen drive usb2 to the front slot, it doesn't work like usb2 but like usb1.
If I connect this pen drive to the rear slot, it works fine !
  • max7452 Feb 08, 2010
    I am not sure about your reply.
    My CPU is Sempron 2800+, do you think that I have to change my CPU ?
  • max7452 Mar 15, 2010
    No, I solved so: all USB plugs to be used on MSI MB should have red (pins 1 & 2), white (pins 3 & 4), green (pins 5 & 6), black (pins 7 & 8). Pin 9 (key, no hole), pin 10 (hole, no wire).
    I removed the last black wire and it fixed my problem !
    President:
  • 1,447 Answers
May be problem on front USB port in CPU.Connection are very loose,so ti can detect.
Change or replace cassing.
Posted on Feb 08, 2010
  • Sazeed Computer
    Sazeed Computer Mar 15, 2010
    Not cpu i mean change cassing.
Bad front USB ports on a Compaq Presario 5000
please re-insert the cable of the usb to the motherboard. i believe that there are 4 pins on usb1. now if this usb1 doesn't work, try the usb2. be careful when inserting the cable.
Mar 05, 2010 | Compaq Presario 5000 PC Desktop
Do the motherboard have an usb plug for front case usb and how tu plug it
this woudl depend on the motherboard but yes most do. look for a silk screen mark on the board marking USB1 or USB2. look at the yellow connectors on this pic for an idea of what to look for
http://www.asusreviews.com/forum/images/assets/fried%20motherboard.jpg
they can be found usually on the bottom front of the board when the board is verticle
Feb 11, 2010 | Dell OptiPlex 160L (160LMIN) PC Desktop
MS-7142 motherboard:connecting jusb1 and jusb2 from panel of emachine
I have had some pretty good luck using MSI motherboards.
If you follow this link, you will be able to download your drivers and owner's manual for your motherboard.
You'll find a picture in the manual with instructions for those front USB ports.
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=173
good luck
tony
May 20, 2009 | MSI K8MM-V Motherboard
Usb
please click follow:
http://www.pctechguide.com/tutorials/MBoard_USB.htm
acording the table and picture you can make easy to correct your USB connection.
hope help you fix it, any question send any time please!
please take a rating let me know how much helped you, thanks!
May 17, 2009 | MSI 865PE Neo2-PFS Motherboard
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
Abit Kg7-Lite motherboard USB2 pin Locations desperately needed!
Lay case down with the bottom in front of you. Looking straight down at the row nearest the case bottom reading right to left there will be two rows of four pins.
Reading right to left the row closets to the case bottom the first lead is vcc1, next usb1-, next usb1+ and grnd1.
Top row reading right to left is vcc2, next usb2-, next usb2+ and grnd2.
I just replaced bad caps on my kg7 and had to remove the motherboard for the repair so I just reinstalled my front case usb ports.
Help this helps.
anon paranoid
Feb 18, 2009 | Abit KG7-Lite Motherboard
Facing problem with usb of motorockr e8 ?
There are two type of portsin USB enabled PC one is Type USB1 & Second is Type USB2. USB2 is faster and is compatible with most new devices. most of the flash drives when attached to USB1 prompt a message to attach to USB2 port to work faster. I am using E6 & it works fine with my Laptop & Desktop. So plug the cable into a different USB.
Jan 03, 2009 | Motorola Mobility ROKR E6 Smartphone
USB2 Problem Windows thinks My card is USB1.1
what do you mean when you say that the 4 USB2 ports are all occupied?
when you say that there are 2 USB1 ports on the back of the case: are those ports connected to the motherboard at all?
what devices are you using to test your USB ports? is it possible that those are USB 1 devices?
Mar 28, 2008 | Microsoft Windows XP Home Edition
Usb ports
Go into your Device Manager (you didn`t say which OS).
Under USB you should have something like Enhanced Host controller.
That is USB2.
If you haven`t got it, your on USB1.
Normally if you only have USB1, and you plug a USB2 capable
device in, you will be told `this device could perform faster`.
Dec 26, 2007 | Computers & Internet
MSI K8MM-V Motherboard Logo
237 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
