Question about Hotpoint WMA40 Front Load Washer
Power cut other day in middle of wash cycle. Machine did not restart after power restored. Door light flashing. Switched off at mains and then on again after turning dial to off. Still flashing. Was able to open door as cycle I think was at rinse stage so not much water in drum. Emptied clothes out. Thought that door switch had burned out so got a replacement from internet store. Replaced switch today. Still no joy. Tried to put programe dial back to orginal setting as per troubleshooting bit of manual. Tried also to set dial to ! to reset - still no joy. Door catch does engage firmly and hold closed. Wonder now if power outtage has damaged main board. Any suggestions..... Is there a combination of button presses I can use to reset if the porcessor is "confused"?
  • jcr0689 Feb 08, 2010
    Dorr definitely shutting and catch engaging properly. Will try looking at blown tracks on board now. Machine is about 4 years old now wo well out of warranty.
    Thanks
    Brigadier General:
  • 3,917 Answers
Power interruptions are never good. Door lock light flashing is not normal either, check to see if door is shut properly, another problem could be a track blown on control module, you would need to remove front console to check this.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Posted on Feb 08, 2010
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door light flashes 4 times and can hear 4 clunks?
First measure the door lock, make sure it's fine, then ensure that there's current flowing towards the door lock. if it'll trip all the electricity out you'll need to ru very close inspection or to replace the main circuitboard
Update me about your progress
Jul 24, 2009 | Washing Machines
Close inner door
That is a problem with the door latch.
To start move the cycler to the end to ternminate the cycle, and turn off the appliance.
Then unplug power cable, or trip circuit breaker, cutting power for five minutes.
If when you restart the machine you still get close inner door message, then that means that the door latch must be replaced.
Mar 01, 2009 | Dyson Flowcheck CRO1 Front Load Washer
Door Lock
door lock blown this sometimes blows tracks off the main pcb behind the control panel. appliance doctor
Jan 29, 2007 | Hotpoint WMA44 Front Load Washer
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Hotpoint WMA40 Front Load Washer Logo
46 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
