Question about Nintendo Wii Console
Wii has no power to it. There is power to the putlet it is plugged into. This happened after I accidently turned the wall switch off the controlled the power to the outlet that Wii was plugged into.
  • 53 Answers
The power cord or power supply got shorted out.
Posted on Feb 08, 2010
When i try to turn my Wii on it will not come on there are no lights or anything how do i fix this problem
This happens if you have had a power outage. Here's what you should do:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
  3. Unplug anything connected to the USB ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Hope that works for you.
May 21, 2011 | Nintendo Wii Console
Tip
Wii won't turn on after a power outage.
Hey, recently had a power outage and now your Wii won't turn on?
Well unless your Wii is completely fried from the storm then this should work (It has for me every time I have had an outage).
After you find out it's not getting power then just unplug the power cable from the wall and from the Wii. Normally I unplug it for about 12-24 hours then you go plug it back into the wall, plug it back into the Wii, look at the power button and if it is red/orange then it has been fixed and you should never have a problem with it again unless you keep it plugged in during a thunderstorm/power outage!
This has happened to me about 8 times and this method worked every single time!
on Jan 26, 2010 | Video Game Consoles & Games
Wii stopped working and will not power up
The first thing Nintendo will ask you to do here and it works if there is no damage to the system or power supply is this.
Unplug the power supply from the Wii AND from the wall. Leave it unplugged for at least 2min (again at least 2min) so it can clear out. Plug it back in to the wall and the Wii and it should work.
Assuming your wall jack is good try to hook up a lamp or something to it. Or if it has the reset button on it then hit that to reset the internal breaker on it. And follow the above tip. Lastly make sure there is no light switch tied to that electrical socket that might of been turned off on accident. All common sense things, but easily missed also. If none of this works you must assume power supply (easy to replace at most game outlets or retail stores) Or there is damage to the Wii!!!
Hope it helps rate accordingly.
Justin
Jul 29, 2010 | Nintendo Wii Console
Power does not turn on
Justin
Jul 28, 2010 | Nintendo Wii Console
When my son pushes the power button nothing happens, it will not start
Hello :
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
While you're waiting, check the AC Adapter for the following:
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power.
If that didn't help , then I recommend you to replace your Wii with new one if you still have the guarantee !
good luck .
rate please !
Mar 26, 2010 | Nintendo Wii Console
Wii will not turn on, all cables are connected and plugged in
Hello :
good luck .
rate please !
Mar 23, 2010 | Nintendo Wii Console
Wii won't turn on
Hello :
good luck .
rate please !
Everything is plugged in, and it wont turn on
It seems even 5th or 6th problem is this. The AC adapter needs to be reset. Unplug it from the wall outlet for 5 to 10 minutes (NOT from the Wii, it HAS to be from the wall outlet).
Considering how often I see this problem, I'm amazed Nintendo didn't address it in their FAQ on the Wii.
This is a common problem with the Wii. As I said, I'm very surprised Nintnedo didn't cover this in the owners manual FAQ, considering it happens almost every time there is a power surge or the power goes out, etc.
Even if it's hooked up to a surge protector, this happens. Power comes back on, but the Wii appears dead. It won't turn on, and the LED indicators won't light. If there was a power surge, or the power went out,etc...anything, this will happen. The problem is with the AC adapter,not the Wii itself.
You need to reset the AC adapter to get the Wii to work again. There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 10 minutes, the red led on the front should be lit up.
Nov 22, 2009 | Nintendo Wii Console
My wii will not turn on, i have everything plugged in the rite spots, it was working just fine the other day, this is the second time this happend . do u know why?
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  4. While you're waiting, check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
  5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
    • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
    • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
    • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
    • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
    • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
    • Once plugged in, check the power light on the Power button to see if the system is receiving power.
See the following webpage @ Nintendo for more information:
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#no_power
Oct 21, 2009 | Nintendo Wii Console
No power to wii
Apr 11, 2009 | Nintendo Wii Console
Nintendo Wii Console Logo
134 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
