Question about Denon DN-V210 Player
When loading a disc it reads disc err - Denon DN-V210 Player
Disc read err
Looks to me you can put in a variety of disks, But to make sure it is not just a disk that was in the sun or so, try it with a bought DVD. If that still giving problems, you could try to clean the laser, with a special cleaning CD / DVD.
Special if someone smokes in the car.
Jun 12, 2014 | Soundstream VIR7355NRBT Car Video Player
Lexus 2001 is 200 6 disc stereo error 1 code shows when trying to play cds
Error 1 - "disc is dirty, damaged, or is inserted upside down"
I quote other solution comments:
I've been getting the Err 1 and Err 3 for a while now, my headunit needs replacing but I haven't had chance yet...
I've found that the cold weather makes it worse as the CDs get that cold they are covered in condensation so the CD has trouble reading them..
In my experience when you get an Err 3 it's basically knacked and needs replacing and Err 1's can sometimes be read problems - what's the disk like?
Mine has started giving Err 1's on brand new CD's (not CDRs) so she's probably having trouble focussing....
If the car is less than 5 years old the headunit should be covered under warranty (ie free).
Hope helps.
Apr 02, 2011 | 2001 Lexus RX 300
1999 Chevy Lumina won't play any CD, display reads 'ERR'
Hi:
Unfortunately, the ERR is a disk read error, and usually caused by the laser being out of alignment. It seems in my experience that An aftermarket deck is a cheaper solution than having it repaired.
Nov 20, 2009 | 1999 Chevrolet Lumina
Incorrect disc, err when disc is put in,
it is not recogonizing it
meaning you might have a blu-ray instead of a reg dvd
Nov 16, 2009 | Televison & Video
DVD player locks up, won't read discs
its about time you get a new DVD Player...What type is it??? if it is a expensive one it is probably worth getting repaired but if it is a cheapy..then throw it away coz its not even worth looking at...there are the biggest pain to fix!! Best solution is to buy a new one!
Aug 11, 2009 | Televison & Video
Sayes disk err can read disk
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
CLICK HERE TO ORDER YOUR NEW REPLACEMENT DRIVE(ROM)
Mar 21, 2009 | Capcom Resident Evil: Code Veronica X
Replaced radio with one from same model year. Displays Err 01.
this generally means the laser is either dirty or the cd player is shot, err 01 is a disc reading problem. Try cleaning lens with cleaning disc first if this does not help i would replace the unit with another. i would recommend replacing it with a cheap aftermarket stereo.
Nov 18, 2008 | 1997 Saturn SL
Pioneer cdxfm128 12 disc changer
Err 11, Err 12, Err 14, Err 17
Dirt or a scratch on the disc stops the laser
beam from being able to focus.
Dirt or a scratch on the disc hinders the track
Clean or replace scratched disk.
There ya go, clean or replace the cd that is displayed.
Nov 15, 2008 | Car Audio & Video
Kenwood KDC-MP528 CD TOC ERR
Every one of those Kenwoods that I have fixed with that error needed the laser pick up replaced. so there is no easy fix for it.
If you have tried several disc's and they all have a TOC err, and you know the disc's are in decent condition, then you will need the pick up replaced.
First try cleaning the disc you are using. I use windex and a soft cloth like a bath towel, it works great at getting fingerprints and other stuff off the disc without scratching the disc. A bad fingerprint or a bad scratch right at the innermost part of the disc (where the TOC is located) will cause any CD player to not read the TOC, producing a TOC ERROR. you never know, you might get lucky.
Jun 17, 2008 | Kenwood KDC-MP528 CD Player
Denon DN-V210 Player Logo
Top Denon Televison & Video Experts
Jonathon summesfield
Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
