Question about Smeg Ovens
I have a Smeg SUK80MFX oven. When the oven is on the fan is very noisy. How difficult is it to replace the fan motor ?
  • 417 Answers
Not too difficult, but you will need to remove the back of the oven from behind to get to change the fan.
Then its a case of disconnecting the wires, unbolting the fan, fitting the new one and reconnecting.
Remember to turn off the power bfore starting work.
Posted on Feb 08, 2010
Oven SMEG SUK61PX8 Fan motor working but the fan slipped of motor rod. There are no signs of break there is no thread on rod. The only thing I have is the fan blade on which there is the nut and a hole...
Replace the fan motor, the rod is one unit with the motor, half moon shaped and threaded at the end, normally left hand thread
https://www.google.co.uk/search?q=SMEG+SUK61PX8+fan+motor&espv=2&source=lnms&tbm=isch&sa=X&ei=rY6wU_uRMYfGPfrWgfAN&ved=0CAcQ_AUoAg&biw=1366&bih=643#facrc=_&imgdii=_&imgrc=_rJYFUaBeWyYSM%253A%3Bc9wu4bCdifNlUM%3Bhttp%253A%252F%252Fthesparesshop.co.uk%252Fmedia%252Fcatalog%252Fproduct%252Fcache%252F1%252Fthumbnail%252F600x600%252F9df78eab33525d08d6e5fb8d27136e95%252F4%252F9%252F492831433611_1.jpeg%3Bhttp%253A%252F%252Fthesparesshop.co.uk%252Fsmeg-circulating-fan-oven-motor%3B600%3B600
Jun 24, 2014 | Ovens
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 07, 2011 | Smeg Ovens
Oven fan working. just no heat.
Most common problem will be a faulty oven element. Also check the wiring at the oven element terminals, it could be burnt off.
Feb 17, 2011 | Smeg SE280X Stainless Steel Electric...
My smeg oven has a terrible noise in the fan on right hand side. My husband thinks the bearing has gone. As it stops quicker than the other fan.
It is going to be a worn bearing, or a loose or broken fan blade.
It more than likely means that you are going to have to replace the fan motor complete
One thing you can try is to spray the motor bearings with WD40, this may help to quiten it down
Hope this helps.
Dec 21, 2009 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
Noisy fan in Smeg oven SA398X
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Apr 18, 2009 | GE JGRP17 Gas Single Oven
Fan but no heat
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Smeg SNZ91MFX1 Fan heating not working
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
256 people viewed this question
Top Smeg Ovens Experts
ashburton
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
