Question about Dell OptiPlex GX270 PC Desktop
Installed new hard drive and dell will not reconize it as primary drive
    Problem Solver:
  • 19 Answers
Make sure that the jumper setting of your harddisk is properly mounted in master and connect the IDE cable to IDE 1 or SATA 1 connector...
Posted on Feb 08, 2010
Why won't my dell laptop cannot read the primary internal harddrive?
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 08, 2012 | Dell Inspiron 1545 i15-143P Jet Black PC...
PUT IN NEW HARD DRIVE, BUT IT DOESNT RECONIZE NEW HARD DRIVE..
How high of a gigabyte does the motherboard support for hard disk drives? Do you need a newer controller? Do you need to install the driver for the drive or boot from a boot disc to install the drive?
Jul 31, 2010 | Dell Computers & Internet
I put a new Hard drive in my sony viao VGN-NR260E notebook.. It reads the hard drive is there and everything but when tring to load windows xp its not reconizing the hard drive to load windows..The hard...
You must partition the new hard drive, sometimes that step can be bypassed by just hitting Enter at the prompts. It has to be partitioned and then the partition has to be formatted through the Windows setup routine. By sure and partition it as a primary partition.
May 15, 2010 | Computers & Internet
Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
Hard Drive not found
try checking this issue using some other HD if the other one works fine then get this one replaced..
May 30, 2009 | Dell Latitude CPI-D Notebook
Does not reconize hard drive
turn off the laptop and then take out the hard drive from the laptop. Go ahead and reseat it back into its slot and then turn on the laptop and press F2 to go into the BIOS. It should see it in there. If it doesn't then you know the hard drive is bad and will need to be replaced.
May 18, 2009 | Dell Inspiron 2650 Notebook
I have lost the scsi drive on a dell 1600sc and would like to convert to sata. During boot up the sata controller is reconizing the 2 hard drives but, come but with "no primary drive found"
The best thing to do is reinstalling SCSI, SATA can only manage two disk per channel on this server, and the data transfer time is longer.
If you set SATA, check jumper settings, that is probably reason why you get no primary drive.
Also check bios settings , do hdd auto detect and save in bios if you want to use sata.
If instead you want to go back to SCSI, download the drivers from the link below.
Download page from Dell.
Mar 03, 2009 | Dell PowerEdge 1600SC Server
Dell Dimension 8250
Yes you need a new hard drive
Dec 09, 2008 | Dell Dimension 8200 PC Desktop
Installed new hard drive now will not boot
1. First of all, you must open the computer case (with power off), and werify the power cable and data cable of hdd. please detach and put them right back.
2. then power on your pc
3. you MUST press F2 for setup utility in order for correct setings of your bios. the message "strike F1 to retry boot, F2 for setup utility" came from the computer bios, not from Windows XP CD.
4. verify if you followed the correct procedure of installing an new hdd as is described on page 66 of owner's manual from dell.
"Installing a Hard Drive
1 Unpack the replacement hard drive, and prepare it for installation.
2 Check the documentation for the drive to verify that it is configured for your computer.
3 Remove the hard drive bracket (see page 64).
4 Attach the hard drive to the hard drive bracket:
a Place the small bracket tabs into the drive-securing screw holes on one side of the drive.
b Gently swing the drive toward the bracket and align the three screw holes on the other side of the
drive with the screen holes on the bracket.
c Attach the hard drive bracket to the hard drive.
d Insert and tighten all three drive-securing screws.
5 Install the hard drive:
a Place the two bracket tabs into the drive slots inside the bracket for the additional hard drive.
b Swing the bracket forward so that it is flush with the bracket for the additional hard drive.
c Replace the bracket-securing screws.
6 Connect a power cable to the drive.
7 Connect the data cable to the drive and to the system board (see page 53).
8 Close the computer cover (see page 75).
NOTICE: To connect a network cable, first plug the cable into the network wall jack and then plug it into the
computer.
9 Connect your computer and devices to electrical outlets, and turn them on.
See the documentation that came with the drive for instructions on installing any software required for
drive operation.
10 If the drive you just installed is the primary drive, insert a bootable floppy disk into drive A.
11 Turn on the computer.
12 Enter system setup (see "System Setup" on page 80), and update the appropriate Drive option.
13 Exit system setup, and restart the computer.
14 Partition and logically format your drive before you proceed to the next step.
See the documentation for your operating system for instructions.
15 Test the hard drive by running the Dell Diagnostics (see page 36).
16 If the drive you just installed is the primary drive, install your operating system on the hard drive."
that's all
Sep 19, 2008 | Dell Dimension 3000 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
162 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
