My toilet sometimes that 2 to 3 time to flush correctly. do I have to replace it or can it be fixed.
  • 767 Answers
You need to raise the water level in the tank so you get more water to the bowl when you flush the toilet. You can do this by adjusting the float most toilets have a water level line in the back of the tank adjust the float to this level and flust it. You can also adjust the flapper to open more when the handle is pushed they usually are connected to the handle with a chain and adjusting a link or two will allow the flapper to open more when the handle is pressed.
Posted on Feb 08, 2010
My toilet flushes inconsistenly. one time it goes complete another time it doesn't flush all the water. My toilet is over 30 years old, is it posssible that the flap that controls the water is broken and...
I have worked on these for many years. The flapper that's attached to the chain and handle, sometimes drops to soon before the tank gets to fill up enough to flush completely. If the flapper has not been changed for some time, it would be a good time now. I wouldn't change out the toilet unless it is cracked. This is a well made one, and I would want to keep it.
Nov 24, 2009 | American Standard 6751 'The Standard...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Sep 27, 2009 | Home
Does not flush completely. Works 2 out 3 times.
Needs new flushing mechanism. Remove Cistern, Remove flush siphon and either replace siphon washer or replace complete siphon.
Jun 09, 2009 | Porcher 40050 Classic Elongated Toilet...
Cadet 3 round bowl toilet not flushing all from bowl
You are probably correct, the water level needs to be raised. There are many different toilet tank systems, but all have some way to control the water level in the tank. Let me know if you need help figuring it out...
P.S. You'll have to take the lid off the tank, first...pardon me if that is too obvious
May 08, 2009 | American Standard Cadet 3 Right Height...
Half flush doesn't stop running
Yes, If I remember correctly you need to replace the flush valves. I cant remember if there is just one or two valves but they need to be replaced. go to your nearest plumbing supply house (a home improvement store will not carry it) and get a new valve. This will fix your problem.
Apr 21, 2009 | Home
Only hot water in sink/basin when the toilet is flushed
I always think I have heard it all at times and then a story like yours rolls in....Please call a plumber,I know what I am doing and you are not going to be able to solve this online. The faucet and toilets are never plumb together much less 2 areas as you have ...so please call a plumber this time...Please rate and this is not Inappropriate.Thanks jj505. Any other ?s please ask. Are you in Ga.30097
Apr 06, 2009 | Plumbing
Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Mar 16, 2009 | Kohler K-3489 Cimarron Comfort Height...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
