Wiring a Dayton Greenhouse Thermostat to control an exhaust fan
Previous greenhouse owner left me with a Dayton Thermostat.  It has three screws where wires can be attached. I read that wires are attached to 2 of the 3 screws depending on whether the thermostat is controlling a heating or cooling device.  I am confused because only 2 wires will be leaving the thermostat. I am use to devices that have 2 white wires & 2 black wires leaving the device.  My guess is that the 2 wires leaving the thermostat are connected to either the white wire or the black wire of the line to open & break the circuit.  The directions on the thermostat itself are written for an electrician & I don't understand them.  For example, on the thermostat itself it says "opens red to blue on increase" ?
AAAA
Posted on Mar 26, 2008
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Mar 23, 2014 | Dryers
Dayton 1HLA3A greenhouse fan blades do not turn unless I spin them to get started. Is this a capacitor issue?
fan starter in side there is a starter black box on wiring with c66 something on it change that. there are lots of these with the same number but you need the same uF number 1-4uf on most can go higher. get the same uf as the one in the unit.
Sep 21, 2013 | Dayton Dryers
What are the most important things to consider when building a greenhouse?
I would say the two most important issues are ventilation and heating. These are both important for the health of the plant. Still air encourages pathogens and discourages photosynthesis. Heating is necessary to keep the temperature at the plant's optimal level.
Jan 29, 2013 | Garden
Where can you order flowers & plants like the greenhouses have?
You check out parkseed.com or gurneys.com. Both have the same buy one take one deal so just choose the best one for you. Now for nursery catalog you can refer to wasidegardens.com and others you can find online. I love gardening which brought me to having a greenhouse garden. Although building greenhouses are very expensive the benefits it brings compensates for the expenses. Having your own greenhouse enables you to save grocery expenses. You will have a regular supply of fruits, vegetables and even flowers. And you have the control on planting what you want. You also have a place to relax and meditate.
Oct 05, 2012 | Educational Insights GeoSafari GreenThumb...
My Dayton 4lz94 greenhouse thermostat doesn't activate at the set temp. But will turn on when temp is about 5 degrees below. Set temp. Is there a sensitivity adjustment to calibrate for activatio
I am having the same problem with my Dayton greenhouse thermostat, this question was posted in the wrong section...but if you find a solution I'd like to know. I am having problems with the heating thermostat as well as the cooling one.
Jan 27, 2012 | Ovens
We have a heating/cooling system (Bryant) located outside. The heating unit runs on propane gas. The unit exhausts hot air while running. I assume this is exhaust from the burning gas. I have wondered...
Carbon monoxide would not be good for the environment of an enclosed greenhouse.
A good analogy would be venting your car exhaust into the greenhouse.
Sep 06, 2011 | Heating & Cooling
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near...
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Dec 28, 2010 | Dayton Electric Heater
Can the G73 be hooked up to an wall thermostat and allow it to over ride the unit thermostat? I want to install this is in a greenhouse and would like to have the thermostat on the wall down lower and not...
Yes, but it will require some knowledge of electric to do that. You will need a line voltage thermostat and mostly like have to have that run a contactor that will be wired to bypass the heater thermostat. A good electrician should be able to to this for you very easily.
Nov 09, 2009 | Dayton G73 Utility Heater
No set-up for a Naan Irrigator greenhouse 8x6x7
try this link
http://www.naandanjain.com/e/Knowledge_Desk/Greenhouses%5B107%5D.htm
Jul 30, 2009 | Rion 8x8 Hobby Greenhouse
Heating & Cooling Logo
1,308 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
