IP 3300 refilling of ink tanks possible or not
Is it possible to refill the tanks of the pixma iP 3300
I picked up the following info on Google.
Dees
Canon ink level monitor - how to disable
Most Canon Pixma printers including MP500, 510, 520, 530, 540, 600, 620, 630, 640, 800, 810, 830, 960, 970, 980, 990, MG5150, 5250, 6150, 8150, MX700, 850, 860, iP4200, 4300, 4500, 4600, 4700, 4850, 5200, 5300, 6600, 6700, iX5000, PRO9000 etc. are programmed to stop printing, before any ink tank runs out of ink.
Refilling the Canon CLI-8, CLI-521, CLI-526, PGI-5, PGI-520, PGI-525 ink tanks doesn't reset the ink levels in printer software, so the printer may not print - even if all ink tanks are full. All the ink information comes from a small IC chip fitted to each ink tank. There is no connection between actual ink levels and the ink level monitor (ink gauge).
To make the printer work again, you can:
1) fit a new ink tank (or chip)
2) reset the "empty" chip back to full using a
chip resetter (if available for your printer model)
3) use auto-reset ink tanks/chips (if available for your printer model)
4) Disable the ink monitor.
It's easy to disable the ink monitor...
Simply read and follow the messages from your printer (on screen) similar to ones shown below. If you use a multi function (MP) printer, the messages should display on the printer LCD panel.
Important: When ink monitor is disabled, ink level indicator (for that ink tank) disappears and the printer will not stop printing, when out of ink. Inspect ink level in each tank periodically (by removing it) to avoid running out!
Note: Ink level monitor function will be restored to normal by fitting a new ink tank (or chip).
1) When the printer software decides one of the ink cartridges is empty, you should get this message (or similar). If it doesn't appear straight after refilling, don't worry. The printer doesn't see the cartridge(s) as empty - yet. Just keep using the printer as usual...and wait for the message to pop up.
Click OK to continue...
2) Then you will get this message:
Click Yes to continue...
3) Then you should get this message:
4) Finally you should get this message:
Press the "Resume" (flashing) button on the printer...and start printing. That's it!
If your printer doesn't have a Resume button, use the OK , Stop, Cancel or whichever button you would use
to clear "out of paper" etc errors. Hold the button until the LED stops flashing or the message disappears.
Note: You will have to repeat the whole process with every cartridge that goes empty (first time only).
Canon chip resetters are now available for PGi-5, PGi-520, CLi-8 & CLi-521 ink tanks.
If you need any help with this, please contact us
Posted on Mar 08, 2012
I HAVE HP DESKJET D1460.I FILLED MAGENTA IN TOP,CYAN(BLUE)IN RIGHT BOTTOM & YELLOW IN LEFT BOTTOM.BUT ODD(WRONG) PRINTING OCCUR.PLEASE HELP ME FOR REFILLING HP NO.22 CARTRIGE.
Posted on Jun 14, 2008
  • 65 Answers
Yes it is possible, Try injuctions to refill your cartidates.
Posted on Feb 23, 2008
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Resetting canon IP4600 printer after refilling ink tanks
Many ink suppliers can supply you with replacememnt chips or a reset tool. You may need to call a few before one will be willing to sell these to you but yiu will find them eventually.
Sep 21, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
How to Override Ink Level Gauge When Using Refilled Cartridges
This maybe in the manual under ink tank replacement, most cannons have this, but keep in mind that sometimes the ink feed tubes to the print head get clogged and then the printer will report no ink at all, these cansometimes be cleaned by soaking them in acholol
May 28, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Canon Pixma MP950 Ink Refill Error
replace the cartridge with a Canon as the chip has gone on the cartridge.
this is the only way around it with the mp950.
This is to stop them being refilled
May 22, 2008 | Canon Pixma MP950 All-In-One InkJet...
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error U130 Cannon ink tank
it is possible that the ink chip is damage. try to buy another. or you can buy original ink to make sure the printer is ok.
Apr 16, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Error messages: U150 + Ink tank errors have occured
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Refilling ink tank
please donot use refilling system it is not for printer
it is new catridge after finishing you can refil for once dont use more times
it depends upon refilling-the quantity-before refilling you should clean with boiling water and then start refilling-if you shake the hands it ink will come out nozziles then use if not see the contacts of the catriges-if not just replace new catridge
Dec 28, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Refilling ink cartridges
I don't recommend refilling your cartridges.If if is not done properly the will leak and create a mess in the machine. I would always recommend new manufactures cartridges or a reputable re manufacturer
Nov 29, 2007 | Canon PIXMA MP830 All-In-One InkJet...
485 people viewed this question
jasbo
jasbo
