Question about IBM ThinkPad T20 2647 Notebook
RDRAGO@ITS.JNJ.COM I HAVE POWER TO MY T-40
I HAVE POWER TO MY T-40 COOLING FAN IS RUNING NO VIDEO AND HARD DRIVE WON'T START. BEFORE MY LAPTOP WOULD FREEZE UP AFTER A FEW POWER UP'S IT WOULD START AGAIN. NOW NOTHING . NOW JUST A POWER LIGHT AND COOLING FAN RUNNING BLACK SCREEN. i TRIED A DIFFERENT HARD DRIVE WORKED ONCE BEFORE NOW NOTHING....
The video card in your Motherboard seems to be having some problems...
Either go to a guy who can repair your motherboard or buy a new motherboard for your laptop..
Posted on Feb 19, 2010
I replaced a video card... now the computer won't start at all
did you move any power or data leads around
is the video card a new one that is compatible with your motherboard
check all power and data leads that attach from motherboard to hard drive for secure dust free connections even a loose fan lead connection can cause you problems
if its a 40 pin flat ribbon ide it will be suspect
also check the video card socket for dust and for compatabilty
hope this helps
Jul 27, 2012 | Intel Desktop Board D845GLVA...
Presario2580us pwers up and fan run but (1) battery wont charge (2) harddrive wont work are these two issues related? if so will removal of battery allow harddrive to run. if so how do i remove...
These two problems could be related in the way that a power surge could have fried the hard drive and the battery. However that is not very likely. Even if that were the case you still have the same problem. A battery that won't charge, and a Hard drive that won't work.
Here is an included link to the service manual for your 2500 series Compaq presario.
http://h10032.www1.hp.com/ctg/Manual/c01122313.pdf
in the manual just check on the removal section, then the sub-section for the battery, and hard drive removal.
I was able to find your battery on-line for $40.
I found several Hard drives online that would fit your laptop. The range was between 40-75$, depending on how much space on your HDD you desire. What you had in your laptop to star with was only 40 gigabytes, or GB. an 80 GB drive would cost you only about 40, while a 250GB would run closer to $75.
Your battery is a flip of a latch, and you should be able to slide your battery out of the Left side of the computer if I am reading the diagrams correctly. Replacement would be the same, but in reverse. Gently slide battery in until flush with outside of computer, then latch shut.
Your Hard Drive is simply using a small Philips screw driver to unscrew two screws from the4 underside of the case. These screws will be about 2 1/2" apart towards the front edge of the computer's bottom. Basically the HDD sits underneath the touch-pad. The old Hard drive that you pull out of your laptop will have a bracket surrounding it, and a Hard drive connector. both the Hard drive bracket, and connector will need to transfer to the new drive in the same way that it was removed from the old drive. Be careful to face the drive up or down the proper direction in the bracket, or the drive probably won't fit. You could even take pictures of the removal, so you have reference for the re-installation.
If this were me, and I had the drive and battery I could do it in 30mt. at most. An unskilled User who took the time to do his/her home-work could do this in under an hour for sure.
Just one last note the proper order for this job would be to unplug the machine, remove the battery, hit the power button for a few seconds(to reduce the risk of electrical surge while working on the sensitive electronics), then switch the hard drive, insert battery, plug in.
I would recommend charging the battery to full the first time before even turning on the laptop, for @ least four hours. Remember the new hard drive will be blank, so you will need to install an Operating system on it. I recommend windows XP home. there should be a sticker with a key code on it on the under-side of your computer. I would hope you would have a XP disc or know someone that can get one for you.
Best of luck my friend.
~Lee-Nuxor~
Aug 31, 2011 | Compaq Presario 2580US Notebook
Dv9000 fan comes on-I can hear the hard drive making noises clickyclicky. all blue lights across the top are on, but it won't boot up. Is this a mother board problem?
I would say its most likely a failing hard drive, as hard drives are not supposed to make a clicking noise. When they start making the clicking noise it usually due to the read/write heads coming into contact with the actual platter where data is stored. This will destroy your data. Usually happens pretty quickly once you start hearing the clicky, clicky. Are you getting to the bios screen when you press the power button to power on? Do you hear any beeps when you power on?
Jul 04, 2011 | HP Computers & Internet
Overheating issues
Most likely the cause of the overheating is the fan its not running properly though you may hear the fan is running but its not working as it used to, also I suggest try to check where is heat coming out from if its on the Hard drive bay, Memory bay or the CPU area, try to fell also the air vent if you feel coming out from it.
You can try this steps and see if it fix your issue.
1. Follow this link to download Speedfan: http://www.almico.com/speedfan443.exe
2. Open and install Speedfan.
3. Launch Speedfan (this usually takes at least a minute to start).
4. Observe the temperature readings you receive. If your temperature readings are above 60 degrees Celsius or higher, especially when the computer is idling, then your laptop is running too hot. If your laptop temperature is below 60 Celsius, then leave Speedfan running and check on it periodically to see if the laptop is heating up (whether idling or in use).
If you are sure your laptop is overheating, then there are a few stopgap measures that you can employ:
1. Place the laptop on top of a cookie sheet.
2. Place laptop on edge of table so that the air vents on the bottom of the laptop are not being blocked.
3. Use a standing fan and turn it directly on the laptop.
Ways to fix laptop from overheating:
Follow this link for pictures and text explaining the next several steps. http://www.insidemylaptop.com/disassemble-acer-aspire-5610z-laptop/
(The laptop model used in these pictures isn't exactly the same as yours but it should be close. Don't worry, this process isn't that difficult, and you won't have to go any farther than removing the cooling fan.)
1. Turn off laptop, unplug laptop, and remove the battery.
2. Unscrew all panels on the back of the laptop.
3. Remove RAM, Hard drive, and cooling fan by following steps 1-8 on the linked website. Skip removing the DVD drive (step 6).
4. Using compressed air, a vacuum cleaner, or an air pump, blow air into the now open compartments in the back of the laptop.
5. Blow out the dust and dirt in the cooling fan.
6. Reassemble and turn on laptop.
7. Run Speedfan and monitor your temperature.
If your laptop is still running hot, then either employ the stopgap measures or take the laptop to a laptop technician. The laptop technician can take your laptop completely apart, reapply thermal grease to the CPU heatsink, and blow out more dust and dirt.
Good luck, thanks for using FixYa, and please post back to this solution if you have any difficulties.
Apr 25, 2011 | Acer Aspire 4530-5889 Notebook PC
How to replace cooling fan
if you are familiar in tearing down the laptop, here is the step by step process... Turn off the laptop, remove the cables and battery.. Then press and hold power button for 8 secs.....remove the screws at the corners of the laptop bottom. Remove the Hard drive, remove the optical drive, remove the screws at the front of the laptop.. Remove the keyboard , and then remove the cooling fan just above the processor and replace it...
Mar 08, 2011 | HP Pavilion zt1260 PC Notebook
Cooling fan runing all times?
try replacing the fan relay switch
Jul 02, 2010 | 2000 Volvo S40
When my laptop is runing it makes this wird noise. It sounds like if it was a vacuum machine inside it. The sound comes from the left side of it. Whars woring with my laptop?
There are only three moving parts in your computer.
1) hard drive
2) CPU fan
3) CD ROM
So--is the noise coming from the side with the vent holes in it and where the heat comes out? If so, it's the CPU fan.
If there is no CD in the drive, you can eliminate that.
I believe the hard drive in this computer is on the right side, so that narrows the cause. Suspect the fan.
Dec 15, 2009 | Sony VAIO VGN-CS215J/W Notebook
My laptop crashed because my cooling fan failed.
It is possible but not guatanteed but fans are pretty cheap anyways so it's worth a try
Sep 21, 2009 | Dell (6F858) Cooling Fan
Itronix VR-1 Go Book Fan Failure message
After bios upgrade had same problem. DISCONNECT AC POWER PULLED BATTERY FOR AT LEAST 5 MINUTES THEN REATTACHED BATTERY AND FAN WORKED ON NEXT RESTART. Also make sure boot menu ( tap F12 at start-up) is set to boot from Hard Drive. I also started on battery power with no ac adapter.
Apr 17, 2009 | Computers & Internet
Dell Inspiron 8100 laptop cooling fans
All fans for cooling cpu plug into a small 2 or 3 pin socket usually white on the motherboard near to the heatsink your fan should have the lead coming from it
fans for video card sometimes takes the power from card or connect to board same as cpu fan but near video card
Aug 08, 2008 | Dell (6F858) Cooling Fan
IBM ThinkPad T20 2647 Notebook Logo
200 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
