Question about Kenmore 98702 Stacked Washer/Dryer
How do you replace the drum bearing from the rear or must you remove the drum from the front on a stacked washer and dryer
  • 767 Answers
You have to replace the bearing from the front and that means taking the drum out from the front. The bearing is bolted in from the inside so there is no way to replace it from the back. Take the front off and take the drum out and you will see the bearing assembly that is held in by some 5/16 screws remove the screws and the whole bearing assembly should come out allowing you to put the new bearing in.
Posted on Feb 08, 2010
Dryer drum loose
you need to remove the drum and examine the rear bearing if worn out then replace it
Jan 27, 2014 | Frigidaire FEX831CS Top Load Stacked...
Dryer works when you help turn the drum. Replaced motor, rear bearings and front bearing of the drum. But dryer wont start from the switch. what would be the reason the dryer wont start without being...
It is most likely due to the motor capacitor being faulty.
Generally a white plastic or aluminium cased cylinder with 2 connectors on it. Each connector may have a couple of wires in it.
Aug 07, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer is starting to squeak, does the dryer have a belt
yes they do...
Remove the panel below the dryer door to access the screws to remove the front of the dryer. Here is a breakdown of what you are looking for. The noise is probably from the rear bearing -http://www.repairclinic.com/referral.asp?R=154&N=1851
and front drum glide - http://www.repairclinic.com/referral.asp?R=154&N=343
Attachment: drum.bmp (Downloaded 17 times)
Apr 29, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a Kenmore stackable washer and dryer and when ever you turn the dryer off you can hear the drum grinding I can hear pennies in it would that make a difference?
You have front felt glide kit that the drum rides on and also rear bearing in back also that drum rides in. One of these is the problem and they both have to be repaired by going thru the front not the back of the dryer.
Jan 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable dryer makes squealing sound. need to find out where to get replacement belt. heard people say open it up and replace the belt but we dont know where it opens up.
probably not belt most likely rear drum bearing which means a complete tear down of dryer from front console,rop and front panel will have to be removed then drum will need to be lifted up out of bearing cup belt removed part is avaiable from sears .com or local parts house unit is made by fridgedaire
Dec 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Access to parts in washing machine
2 men 2 hrs minimum tub halves are bolted together and entire assembly will need to be removed bearing is not a service part entire rear shell will need replacing and probably basket also due to shaft scoring better ck for warranty
Jun 04, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Stackable unit with a squeak
the front panel will need to come off, disconnect power to unit.
remove the angular panel between the units theres a couple of screws behind there to remove the console(it drops sown no need to remove)
next there are maybe 4 screws across the very top of the unit (actually will be easier to remve the entire top of unit)
2 more screws behind the console then release the front panel, need to be mindfull of door switch wires.
ok from here you can reach under drum and release the tension pulley holding the belt( beforeyou do get a feel (you wont be able to see it) get a feel for how it operates and applies tension because youre gonna have to reattach in in alittle while
after that grab hold of the entire drum and give it a good lift off the rear bearing, might need a little ummf but ittl come out. afterthat follow instuctions in th ekit and reassemble unit.
my adive is that you use the supplied screws that hold rear bearing to drum to thread the rear bearing plate ahead of actually trying to secure it. much easier trying to reach in the drum and tightene the screws if the holes are all ready threaded.
Mar 30, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore/Whirlpool 417.99170120 Laundry Center
5303281153 comlete rear bearing kit, should come complete with insrtuction's
Mar 10, 2008 | Kenmore 98702 Stacked Washer/Dryer
Noisy Dryer Drum - Squealing/Grinding type Noise.
I have a Kenmore Stacked Washer/Dryer (Model 417.91702000) that has had the same thing happen. I have replace mine twice . . .It is the rear dryer bearing.
You can purchase a kit that contains everything to replace it.
You have to work from the front, all the way to the back.
Make sure that you also check the felt pad glide on the front door panel (the drum rotates on this). You may need to replace it also, it should have teflon pads built into the felt that the drum rests on . . .
Jan 21, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
140 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
