Question about Zanussi TC7114W Electric Dryer
Zanussi tc711w dryer working but blowing out cold air. wonder if needing reset.
  • 67 Answers
SOURCE: Dryer will not blow hot air
first, check the entire exhaust pipe, most of the time the problem is there. every inch must be free of lint. to take apart most dryers: 2 screws hold on the bottom front panel. those screws are near the floor on the front. once that panel is off, you should see 2 more screws, this allows you to remove the main front panel (the one that holds the door) with that off, there should be 4 screws holding the front drum support on. with that off, you should be able to carefully remove the drum after removing the belt from the motor. to get the belt off, you have to reach in from the bottom and push the tensioner and slip the belt off the motor.
good luck!
Posted on Oct 28, 2008
kachbibi1
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
kachbibi1
  • 979 Answers
SOURCE: electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Posted on Jan 26, 2009
  • 98 Answers
SOURCE: the tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Posted on Jun 07, 2009
michaelcanto
  • 76 Answers
SOURCE: dryer is tumbling but air is cold on TD62 zanussi
is this gas or electric?
Posted on Jul 28, 2009
My dryer is working but it is blowing out cold air
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 10, 2011 | Zanussi TC7102W Electric Dryer
My zanussi xc6 condenser dryer is blowing cold air,please help.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Zanussi Dryers
We have a Zanussi washer/dryer WJS1397W but only a cold feed where we want to put it. We were wondering if this machine could cope with a cold feed only?
It shold not be a problem if the machine gives you a choice choose the cold wash.The manual should tell you which wash cycles are cold wash only.Hope this helps Kind Regards Stefan.
Jul 08, 2009 | Zanussi WJS1397W Front Load Washer / Dryer
The tumble dryer is work but is only blowing cold air
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
Electric dryer blowing cold air
Jan 26, 2009 | Zanussi TC7114W Electric Dryer
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Dryer does not heat up
my dryer work but it does not give heat ( kennmore 70 series)
model# 10062712101
ser: 1216293
i am trying to get the manual for my dryer from kennmore
Oct 26, 2008 | Zanussi Dryers
No heat
there is a main dryer fuse and a heater box fuse,the heater box fuse is the small bimetal fuse on the heater box,replace that and you should be ok,let me know how it goes-mike
Oct 12, 2008 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W Electric Dryer Logo
50 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
