Question about LG HBM-710 Wireless Headset
Can pair, can't connect
Hi... I'm trying to pair my HBM-710 to my Sony Ericsson 710A. It worked for several months but recently stopped working. When I pair it, my phone finds "unknown." That's OK, it used to work. Now, I seem to be successfully paired but when I try to connect, I get the message, "Bluetooth connection failed." The little bluetooth icon on the screen appears and has a < on the right hand side, which I take to mean it's trying.
Any ideas?
Hal
  • csckac Mar 21, 2008
    I just got an upgrade on my blackberry , not a huge jump in models but a few none the less. The LG HBM-710 worked well with the old blackberry and now I cant get it to work with the new BB at all. I cant even get it to see it. I've read all the manuals and I just cant find out if the two are compatible. Any help?
Got the same issue .. i used to use it on a se k750i .. it worked perfectly .. i unpaired the headseat .. and erased the device from my phone .. now i got a se w800 and i can't get to connect it .. it just does not find it .. i've tryed this on several phones and still no solution ... i guess i'll have to write LG a messaage or smth .. good luck!
marius
Posted on Sep 19, 2008
Maybe its already connected to another device, try disconnecting from the other device, then connect it to the one you want to
Posted on Aug 03, 2008
My LG HBM-760 blue tooth needs a pass code to pair with my phone. where would i get the pass code?
my teknic bluetooth told me dat i needed a passcode to pair with my phone but i just dismissed the notice and it worked for me, what i done was searched for devices using my bluetooth, found the phone and it paited up, but when i searched using my phone i needed a pass code,
sorry if ive been no help to ye
Jan 07, 2010 | LG Car Charger For HBM-710, HBM-760...
Cannot place LG-HBM-710 in discoverable mode
It sounds as if the device is not paired with your Chocolate. Press and hold the button on the face of the HBM-710 headset for approximately five seconds, or until the light comes on and stays on steadily, then discover the device with your handset's Bluetooth screen. Once it shows up in the list of devices, select in and pair it with your phone.
Jul 07, 2009 | LG HBM-710 Wireless Headset
Hoe do i put the lg hbm-760 in pairing mode????
Turn it on by holding the power button for four seconds, Then go to your phones bluetooth setup screen, search for new devices, and pair it. The blue led on the HBM-760 will turn solid blue during pairing. It is always discoverable. The default passkey is 0000. Hope this helps.
Jun 22, 2009 | LG Car Charger For HBM-710, HBM-760...
My headset will not pair with my new cell phone
First, open the phone's Bluetooth screen. On the HBM-710, press and hold the button on the face for about five seconds, or until the light comes on and STAYS on. Now find the headset with your phone and pair it.
Hope this helps!
Jun 11, 2009 | LG HBM-710 Wireless Headset
HOW DO I PLACE AN LG BLUETOOTH HBM710 IN "DISCOVERY MODE" ?
Just came across your question while searching for the same answer - Here's what I found out:
When it's off, press and hold the on button for 5 seconds - it'll turn on, but keep holding until you hear the short beep - the light's on and you're where you want to be. Here's the full text that I found from the manual:
-With the HBM-710 off, press and hold the PWR/END button for 5 seconds
(You will hear a short beep and the LED indicator will stay red, when the device enters pairing mode)
-Using your handset, find the "Bluetooth menu" and "search for" or "add" new devices
- Select "LG HBM-710" from the list of devices and pair it with your headset
- When asked for the Pass/PIN code during the pairing procedure, please enter "0000" (4 zeros)
- Once pairing has been completed successfully, you will hear a beep
- After pairing successfully, be sure to "connect" to the LF HBM-710
- If you want to pair with other devices in the future, the headset must be in "Pairing mode"
- If it will be not connected the "Pairing" for three minutes, it will be turned off.
Apr 03, 2009 | LG HBM-710 Wireless Headset
How do you put in pairing mode?
Here's how to get the LG HBM-710 Bluetooth headset into pairing mode:
While the headset is OFF, press and HOLD the power button. CONTINUE to do so even after it has powered up. About 3-4 seconds after the startup beeps there will be one more beep. Then, the red light will go solid.
You are now in pairing mode! Hooray!
Go through the necessary 'Add a Device' steps on your cell or whatever and you should be G2G!
Mar 24, 2009 | LG HBM-710 Wireless Headset
Passkey for headset
I had the same problem on my HTC Mogul; turns out that I had the WIFI turned on while trying to pair. After turning it off I was able to connect by using 0000, which did not work while WIFI was on.
Feb 01, 2009 | LG HBM-710 Wireless Headset
LG HBM 710
Sounds like someone "hacked" your headset and changed the code and display name. if you don't know the new code then my only suggestion would be head to your local distributor (probably a Verizon store) and ask them to reset your headset for you.
Apr 23, 2008 | LG HBM-710 Wireless Headset
LG HBM 730 and VX 9400 pairing problem
I found the solution. The original password setting is a combination of zeroes - at least 4. If you did not originally change your password setting for your bluetooth from the original setting - try that. It worked for me.
Also - Thank you for your reply.
Oct 25, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM-710 Wireless Headset Logo
157 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
coolboyjitu
Level 1 Expert
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
