My friend send me washing machine from hongkong...i can't fix it cause there is no manual...TGC GWD 55 S....i even ask technician to set it up...but no avail... he is asking for the manual...pls i would appreciate very much if you can send me manual of for this washing machine...my email ad...drmisuarez@yahoo.com thanks a lot
  • Gerry Harvey
    Gerry Harvey May 11, 2010
    You need to post the make and model for help...
caroldon
  • 17129 Answers
SOURCE: Hi, my washing machine is
Possible that the drain valve/pump is faulty.Now this can be failure of the pump/valve or the pump is clogged with dirt and so does not work. You need to first check the voltages on the drain pump at the time of drain, if not present the program controller is faulty but if present the valve/pump is faulty. remove from the drain outlet hose fittings , remove the pump and clean or back-flush with jet water, test outside for the pump to work freely , if not the pump is faulty and must be replaced.
Posted on Apr 23, 2011
  • 161 Answers
SOURCE: WASHING MACHINE awm 8163
The door will never open unless the timer is in the off position. Sometimes there is an additional time delay before it will release. If someone tried to force the door they probably bent the latch release. It needs to be replaced.
Posted on Jul 03, 2008
Joshi_Z
  • 567 Answers
SOURCE: Special code for motorola boost t9 i450
hello there....well its quite simple...
1)......there is nothing wrong with your phone ...its your SIM... if it is asking for a PUK (Personal Unblocking Key) code...call your subscriber and ask them for PUK code,entering this code will reset your sim
if u keep entering wrong your sim will be damaged so call them
If the error message is saying sim damaged call them and ask for a "sim replacement" you will get a new sim while you will retain the same number ,however you will lose the phone numbers and other data stored in sim,this can be free but it depends on the company and how 'customer friendly they are
2).......to unlock the phone to any network you need to call the customer care of your original network provider..just keep the model number of your phone number handy (you will find that on the box in which you got the phone)...or the IMEI number (15 digits mostly) by dialing *#06# on your phone or beneath the battery or on the box near bar code....this is a paid service and charges differ from network to network
that should solve the problem.....you will be able to use any sim in your phone of any service around the world
Hope this help
Cheers
Posted on Aug 06, 2008
SOURCE: A4tech PK-7MAR
hello,
1. double click on volume icon on the lower right corner of your screen.
2. click on options, properties.
3. another sub window will appear.
4. in the box, look for mic volume and check on the box.
5. click ok after checking the box
6. another column should appear which is the mic volume. under the mic volume uncheck the mute box.
7. you should be able to use your mic now.
Note:
make sure you inserted the pink plug on the pink socket at the back of your computer.
Hope this post helps :)
Posted on Aug 07, 2008
  • 8 Answers
SOURCE: machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
Posted on May 28, 2009
Who can I call to come and fix my washer?
call in a qualify technician you know or ask a friend to introduce one to u..
Nov 04, 2014 | LG Wm0642hw Front Load Washer 4.0 Cu. Ft....
Westinghouse 55" TV washed out color how to fix
The symptom really sounds like the fault with its T'Con board itself. As a technician, you too might have suspected it; I thinks. Do I've to say more? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 06, 2014 | Televison & Video
Washing machine stop with an error code motor shortning
Good Afternoon Friend,
I understand that your Electrolux washer stopped with an error code of the motor shorting, and you want to know how to fix it. Typically, this is not a do it yourself job, as there are no step by step instruction manuals for this. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to your washer with ease. Hope this is helpful.
-Best Regards-
WP
Jun 18, 2014 | Electrolux Washing Machines
Have a whirlpool AW0 R4205 washing machine. No power even after checking the plug and changing the fuse.
good day,
How long your washing machine? for the machine without power if electronic type of washing machine it will cost you a lot but defend on the model. and not to advise to buy the part without any idea what the exactly the problem,most the electronic type washing machine have a PCB problem, if you buy directly for the part but you dont have the cause why it happen,may be if you put new part will do the same or its will waste your new part.
as an advise as a technician,call the technician and ask how much its cost? for labor and part?
if the cost is halt price of the unit? what or how many month for warranty for the part and service? make think to buy for the new one if your unit is more than 5 years.
Nov 02, 2013 | Washing Machines
Every time i turn the power on, it blows the house fuzes.
Your machine has a serious electrical fault (although the cause may be relatively simple).
Unfortunately, and with the maximum respect, the very fact that you've had to ask this question confirms that you are not a competent person to repair your machine yourself (even with instructions) without serious risk.
All you can do is to unplug your machine from the socket and to call in a skilled friend or repair technician to diagnose and repair the fault safely.
Jun 18, 2011 | Hotpoint Aquarius WD63 Front Load...
Hello there, i have purchased an iTgate TGC 200 broken remote
If you cannot find the original remote, I suggest you buy a universal remote like the Logitech Harmony. Even the cheaper Harmony models will be able to control your receiver. Programming the remote is easy and done on your computer.
Apr 08, 2010 | Televison & Video
When switching the washing machine on all the lights are constantly flashing and they don't stop which stops me using the machine
If the dis[play lights are flashing and you are unable to set and cycles than it could be causes by a number of things. It will need to be properly diagnosed by a technician. It could be caused by a faulty board to a clogged drain or maybe even a faulty water inlet. But will require expertise.Hope this helps
Thanks
Dec 02, 2009 | Hotpoint Washing Machines
Panasonic Panafax UF - 885 unable to send faxes direct
Hi BrendaAsh,
Thank you for the above information.
Please ask rlandriani to access the user parameters on the fax machine and turn the Quick Memory XMT to "Off" or "Invalid".
This should set the machine for direct manual sending without memory intervention.
Regards
Gavin.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Can you send me MBV1976A service manual (Maytag Skybox)
Can you send me a copy of the manual too please? cditty@gmail.com
thanks
Jul 04, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Washing Machines Logo
548 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
