Question about Polaroid FLM-323B Television
Tv power My tv turned itself off and won't turn back on. Have moved it to another location in the house but still nothing. What could it be?
  • Anonymous Feb 22, 2008
    i need a service manual
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
I have serviced many Polaroids that simply go dead. The problem is that all parts are contained in the control box. You cannot buy individual bds for Polaroids. You might check Andrews Electronics or Vance Baldwin for Polaroid parts.
Posted on Feb 23, 2008
WON TURN ON
For the first step, try using the button on the TV itself.
Secondly, check if the power cord is snug, and not burnt. Sometimes after a blackout, there would be a power surge, and that might burn your plug.
If both doesn't work, the fuse in your TV may be blown, or the Power Supply may also be burnt too. If this happens, you're going to have to hire an expert to help replace the broken parts.
Note that in some TV models, the fuse can be replaced by users. If this is your case, try checking the fuse to see if it's blown or not.
Feb 02, 2014 | Panasonic Viera Tc-p42x5 42" Inch Flat...
No power at all after an power outage
Before you investigate the TV and its power supply, have you confirmed that the outlet is still delivering the voltage? Sorry if I ask but you said you turned everything back on after the power failure and I didn't know if you meant equipment in the house or all circuit breakers in the house.
Dec 31, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
Power surge tv won't turn back on
Check and replace its main power regulator board. Before replacing it, check the fuse, can be located on this board itself.
May 08, 2013 | Panasonic Viera TH-42PX80U Plasma TV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
My panasonic th-50px60u television turned itself off last night and won't turn on makes clicking noise when unplugged and plugged back in but then nothing red light flashes
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 29, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have a Sony NSX-40GT1 that won't power on. You can hear the relay click after plugging in, and the red power led comes on, but when you push the power button it does nothing. Any ideas?
I'm having the same problem. Can anyone help. If possible i'd like to fix it rather than go return it. It worked fine for a while and then suddenly started turning itself off. Now every time i turn it on it turns itself off.
Jun 12, 2011 | Sony Google TV NSX-40GT1 40 in. HDTV LCD...
My New Samsung 50" Plasma (PS50C451B2D) keeps
if timer is not activated, your unit needs servicing.
have the power supply check first for output voltages it may not have enough to power up some of the circuits board.
Feb 08, 2011 | Samsung PS50C451B2D 50 in. Plasma TV
Big screen tv turns on and off on its own!
Your TV is being overheated by the location it is placed. try moving it in an airy area and see if the problem still occurs. The turning on and off is a response to overheating sensors in the TV housing and if not rectified it could malfunction and may cause burnout, a possible risk of fire.
Sep 18, 2009 | Proton MM2701VT 27" TV
TV shut off
The set is going into shutdown,there are a few reasons why the circuit is being activated,excessive high voltage,excessive volts supply(poor regulation)no screen voltage or a secondary supply is missing,if you are familiar with tv service you have a few places to check,you will need a volt meter and a soldering iron and the squematic diagram to locate the different circuits mentioned,if you are not too familiar seek the assistance of a servicer.Let Us know if you need more information.
Oct 27, 2006 | RCA F35670MB 35" TV
Polaroid FLM-323B Television Logo
104 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
