Need bios password for toshiba a300 - Computers & Internet
    President:
  • 1,216 Answers
Hi
This is really, really strange but as the BIOS password can be removed only by a local ASP. The technician will remove it and will update the BIOS to prevent such further, unexplained password settings.
Greets
Posted on Feb 08, 2010
RALilja
  • 390 Answers
SOURCE: toshiba SPM30 bios password remove
All you need to do is open one of the covers on the backside of the laptop and remove the CMOS battery (it looks like the size of a quarter) for a few seconds, then place it back into it's holder and put the cover back on. You can then power up the laptop and then re-set up all the settings in the BIOS in order for the laptop to work correctly as all previous settings have been forgotten including the password.
Good Luck!
Rich Lilja
Posted on Jan 17, 2009
  • 153 Answers
SOURCE: lost bios passwrd
Toshiba has a list of models in which the computer randomly changes the BIOS password, prohibiting entry. You need to call them at 800) 457-7777 to see if your model is on the list. If it is, you have an older version of BIOS. They will have you take it to your nearest authorized service center and upgrade the BIOS for you and then you will never have that problem again.
Posted on Feb 01, 2009
SOURCE: bios password reset
Hello, I can unlock ANY toshiba bios password (including tecra, portege, qosmio and librettomodels). If anyone have questions feel free to visit www.laptoprebirth.com or send an emailto conradodav@hotmail.com WE SUPPOR OTHER BRANDS LIKE ACER HP COMPAQ SONY ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
Posted on Jun 03, 2009
SOURCE: reset bios password in satellite 1135
remove the power cable, batter and the cmos battery from the computer, wait a couple of minutes and reassemble. The bios with the password will be reset.
Posted on Oct 10, 2009
  • 66 Answers
SOURCE: I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Posted on Nov 04, 2009
Bios password remove
Basic input/output system, or BIOS, is an interface to start and load the operating system. Making changes to the BIOS will change the way the operating system operates. Sometimes to make changes to the BIOS, you will have to enter the BIOS password. If you have forgotten the password, you can bypass it.
1.Download and install a BIOS utility such as CmosPwd or KillCMOS (see Resources). These utilities will remove BIOS passwords provided you are in MS-DOS or Windows mode.
2.Locate the jumper switch on the laptop's motherboard. You can identify the jumper switch by CLEAR, CLEAR CMOS, JCMOS1, CLR, CLRPWD, PASSWD, PASSWORD, PSWD or PWD label. Once you have found the jumper switch, remove it and place it over the pin that is not covered.
3.Locate and remove the CMOS battery for at least 5 minutes. This will reset the BIOS password. Then enter the generic BIOS password to enter the BIOS.
I hope you find it very helpful. Thanks.
Sep 05, 2011 | Toshiba Satellite A300-0CF035 Notebook
Is there a way to bypass a bios password?
If you set your BIOS password but have forgotten what it is, then the simplest way to reset it is to remove the BIOS battery. You need to be somewhat technically proficient to do so, especially if it's the BIOS on a laptop you want to reset. Some machines have a BIOS reset button on the back of them to reset the BIOS after a failed overclock, but I've never seen such a function on a laptop. You may also try typing in "Toshiba" as your BIOS password if that's the make of your laptop as it's been use a backdoor BIOS password in the past.
Apr 01, 2011 | Toshiba Satellite A300-0CF035 Notebook
There is a bios password. my friend can't remember the password. How would i Bypass the password?
Hi There,
About the only way to reset the BIOS and therefore delete the password is to remove what's called the "CMOS" battery, and then hold down the power button for about 2 minutes, then replace the battery. It's small and may be coated in plastic. You should also have the main battery detached before doing this.
If you go to the below site, you can likely find a picture tutorial for disassembly of your laptop or one close enough to it to go just far enough to get at the battery. Toshiba doesn't provide Service Manuals for disassembly.
http://www.irisvista.com/
Regards,
Selk
How do I deactivate the password from BIOS set-up. My daughter forgot her password!
Try type this password : Toshiba ( If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 11, 2011 | Toshiba Satellite A300-0CF035 Notebook
How to reset bios password on toshiba satellite A300? pls help..
Satellite Pro A300 (PSAJ1E-)
Remove battery and disconnect the AC-adapter then short pad G1 for a minimum of 30 seconds
with a flat-blade screwdriver, the pad is located under the memory module.
This can be accessed from the base of the notebook
Jan 26, 2011 | Toshiba Satellite A300-0CF035 Notebook
Power on bios password removal
open ram bank ... near the ram u will see a small jumper ... turn off laptop remove battery keep short jumper turn on laptop wait few second ... password will remove.. if not let me know
Oct 13, 2010 | Toshiba Satellite A300-0CF035 Notebook
How to remove Toshiba satellite a300-146 bios password?
On Toshiba laptops this can be done only by a hard BIOS reset, and this can be done only by the dealer, by rewriting the BIOS with a special device. Time to take it there, luckily it will be cheap, less than $40.
Jul 18, 2010 | Toshiba Computers & Internet
Insatll windows xp in satellite A300(PSAG4E)
You may need to take your PC to a computer shop or call Toshiba if the BIOS has been corrupted.
Sep 07, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Cmos error message
Just take out your BIOS battery, and wait for 5 min, then put it back!
Or you can try to flash BIOS, if you know how to do this!
Jan 28, 2009 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
389 people viewed this question
David Payne
David Payne
