Question about Bosch Axxis WTL 6003 Electric Dryer
How hard is it to replace the heater of a bosch dryer wtl 6100. Do I have to dismantle the entire dryer or just plug-play from the back side?
    Problem Solver:
  • 5 Answers
Hi - not 100% on that model but many of the recient dryers have their heaters at the raer (as oposed to the around the front door) so are easy to remove after you unscrew and lift off the rear cover... a 10min job once the machine is out.
Posted on Feb 20, 2010
My dryer working but not get hot conden water sign blinking what is this mean.
If dryer is not getting hot check the condition of the heating element(s).
Oct 10, 2015 | Bosch Dryers
Where is the reset button?
Most Bosch dryers have a heater reset button behind the main rear panel. If this thermostat has tripped, there is a REASON, resetting it may make things work for a short time but your issue is bound to return. There are many other things to check on Bosch dryers to ensure proper air flow throughout the dryer and house venting. Pleazer Appliance...
May 01, 2014 | Bosch Axxis WTL 5410 Electric Dryer
Can I stack a Bosch WTL5400 dryer on top of a Bosch Classixx 7 washing machine?
http://www.bosch-home.co.uk/store/product/Connectionpiece/244024
Call the helpline for verification of compatibility prior to ordering.
Feb 06, 2013 | Bosch Axxis WTL 5400 Dryer
What does E1 mean?
Welcome to FixYa.
Can you possibly double check that model number and reply post. I ask because the "E1" error should only pertain to those models which are condensor (non-vented)... "WTL" dryers.
The error indicates either a blocked drain hose or a failed pump. This from Bosch...
E1 Pump failed
(WTL 5400condensationdryer only) Pump failed.
Check voltage at and wiring to pump.
Turn off dryer, measure pump resistance (110 - 136 ?) and replace faulty pump.
Also - Following items apply only to the WTL (Condensation Electric Dryer) models
Cycle is interrupted and ''E1'' appears in display• Condensate hose is blocked in some way. Turn off dryer and check hose.
I'll watch for your reply and try and help you move forward in any manner I can.
Regards,
Macmarkus :)
Apr 14, 2011 | Bosch Axxis WTA 3510 Electric Dryer
We have a Bosch WTL 6301 , as the heater not working so what I can do , I have test the Heater and its Ok but no electric comes to it
Could be a faulty thermostat/s, or the timer control unit could be faulty.
The power goes to the thermostat/s before going to the heater.
Mar 09, 2010 | Bosch Axxis WTL 6106 Electric Dryer
Re-set button location?
you need to remove the back panel the smaller one that covers heater matrix you will find a thermostat with a red reset button on it when you push it it will click and reset however you should find out why this happened before you use it again as it only does this if it overheats.
hope this helps
Jun 29, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Oct 25, 2008 | Dryers
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 6003 Electric Dryer Logo
373 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
