Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
My problem is my speaker and headset is not functioning..wat should i do??
  • 86 Answers
Check your sound card re install the driver
Posted on Feb 09, 2010
  • eranio catabona Feb 09, 2010
    check your sound card re install the driver
How do I get my headset to work on NEC SV8100
to use the headset port you can program a button that toggles between the handset piece and the headset port (under the handset),
assuming that your installer has used standard feature codes, press the following;
? Press Speaker key.
? Dial 751.
? Press an available Function key. (one of your unused 24 buttons)
? Dial 05.
the Function button is now your Headset pickup/release button
Feb 26, 2015 | NEC Lands Phones
My Samsung Wave 525 speaker is not working.
When phone speakers stop functioning the first thing you want to do is try increasing the volume. After increasing the volume to the highest and still the speaker does not work then you are left with no option than to refer to an expert to help fix the speaker by putting in a replacement speaker.
Although there are usually 2 speakers, the loud speakers and the headset speakers if it is the headset speakers then you dont hear what is being said on a call you can use an earpiece or bluetooth device pending when you can get it fixed.
Hope this solution has been helpful?
Jul 17, 2011 | Samsung Star GT-S5233 Cell Phone
My hed set onesaid working wat problam my hed set is rainbow rb 826
one side speaker connection is disconected, re concent it will fix the problem
Jan 17, 2011 | Logitech (980174) Headset
MY RADIO WILL ONLY PLAY THROUGH THE HEAD SET. IT WILL NOT PLAY THROUGH THE SPEAKERS ON THE FARING. I REPLACED THE SPEAKERS AND STILL HAVE THE SAME PROBLEM
Internal issue with the radios amp circuit. The speaker output and the headset output run through different circuits. If you have headset output, all functions prior to the amp circuit are good. Radio will need to be repaired. Contact Iron Cross Audio for repair options. www.ironcrossaudio.com
Oct 04, 2010 | Harley Davidson 426290 AM/FM Radio
Built in speaker does not work but headset is work hp pavilion dv6000. thank you
The speaker of your computer has a problem not the sound card device because when you're using headset its work. Try to use the external speaker when they are functioning, automatically you need to replace your built-in speaker to fix that problem.
May 30, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Headset problem with Uniden 1558
Determine if this is a VOX problem or a headset problem.
Turn off the VOX. Does the headset work for normal transmit and receive?
Remove the headsets. Do the radios work normally on speaker?
Plug one headset in And test with the (other) radio in speaker mode. Does it work? Now turn on VOX in this mode (yes it will work this way). Does vox work (put you mouth right on the mic)
If so swap headsets and try the other.
If one Hset works but not the other its the headset. If neither works its likely the radio ..but before you decide try the same headset experiment on the other radio. Find out which of the 4 devices the problem follows.
Happy New year
Dec 24, 2007 | Uniden GMR-1558 / 2CK 2-Way Radio
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
