Question about Uniden Cordless Phone
Calls coming in, but, phone is not ringing. - Uniden Cordless Phone
    President:
  • 3,278 Answers
Normal 0 Hello.
I would suggest resetting your phones.
Disconnect all phones from the power and telephone line (if there are more than 1 phone on the same line, if not, just disconnect the telephone line). Wait 15 minutes and reconnect the power and line again, one at a time if multiple phones on the same line.
If your phone still does not work, the telephone cable could be bad. Replace the cable.
If you still have a problem, either the phone base is bad or the line is bad. Test with another phone, if available. If replacing the phone and telephone line doesn't resolve after resetting, contact your telephone provider.
Hope all of this helps.
Posted on Feb 08, 2010
4 Suggested Answers
  • 3 Answers
SOURCE: Set not ringing
When you say you are the one responsible for the programming, are you referring to programming the "physical phone" or the PBX and line cards and system functionality?
You should have an extension on your phone. Has that extension for example 222 been translated at the PBX to ring on a direct number -> (xxx) 555-1222
Or by what you are describing, you are more looking at having "shared lines" that ring in multiple locations simultaneously, and once picked up somewhere a "line lock" should be in place?
Posted on Aug 13, 2008
SOURCE: Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Posted on Jan 13, 2009
cnavarro
  • 2460 Answers
SOURCE: The phones won't ring when calls are coming in. The lights on the phone light up but there is no sound
Uh oh, I just saw this. Is it in the main board 101-108 exts, or one of the expansion boards?
Ringing is set 3 ways, by the switch on the side of the phone, by programming, by features. First, make sure the switch is in the ring position and have someone call you on the intercom. If it rings, have someone transfer an outside call to you. If it rings, try dialing 790 on the intercom to reset station features. If none of this works, It's time to look at ring programming. It's done from the system programming mode at the main phone or from a PC. It's program codes 408-410 or section 3.2 from the Maintenance console.
The last ugly thing is it's a hardware failure.
Carl
Posted on Apr 29, 2009
Our phone is not ringing for an external calls but the light is blinking indicating that there is an incoming calls, but calls coming from intercom does ring! meaning our phone is not in silent mode and i...
There are many features which can cause the phone not to ring when incoming calls are on the line. There is a do not disturb key and a mute button on the phone itself. Check to make sure they have not been set. There is an incoming call feature that sometimes needs to be programmed on the phone before it will ring for incoming calls. There is also an automatic answer function that can interfere with ringing too. Instead of listing all of the possibilities, I am including a "cheat sheet" with all of the features & programming for your phone below. Click on the link and scroll through the options to troubleshoot this issue.
If you have any questions please use the comment or reply link near your question on Fixya's website to contact me and I will continue assisting you until this issue is solved.
Sep 14, 2011 | Panasonic KX-T7730 Corded Phone
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do I get edge 120 to ring when outside calls come i? Several of our phones do, but a couple of them don't. Can't find anything in the manual about setting a phone to be one of the phones that ring...
you need to goto the mobile settings and scroll to ringtones and select the ringing tone,volume and whether you want continuos ringing or not is there for you to choose.
Jul 16, 2009 | Lands Phones
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Examples
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Can't call out and Phone keeps ringing on in coming calls
It was all in the outside phone lines. But thanks for the intrest.
Dec 29, 2008 | Panasonic KX-TG1034S Phone
Fix phone line
It sounds to me like the phone line coming into your home has a short on it so when someone calls your phone it asts as you have answered it. Report the line trouble to your local phone provider as "RNA" (ring no answer) normal phone trouble ticket terms.
Nov 21, 2008 | Lands Phones
Why is my phone ringing?
Your Handset has been programmed i guess by mistake to be in the same ring group as the main receptionist for C0-01 . Use Google for programming manual to make changes.
www.heymot.co.uk
Oct 17, 2008 | Panasonic KX-T7633 Corded Phone
Call will not Transfer to Voice Mail
Typically you want your phone system to ring your phones (say extension 10, 11 and 15) and then if no one answers after so many rings the call is transfered to the port the voice mail is on (let's say it's port 16) The voice mail is set to answer right away but does not "ring" until the call is transfered to it. This way (at 4 rings) if a call comes in on line 1 and you answer after 3 rings but a call comes in on line 2 at the same time, the first ring on line 2 will not make the total = 4 and set off the voice mail. I would guess the port at your voice mail is not set to ring and nothing is set up to transfer calls to your voice mail. Did you set this up yourself? How did you program the phone system?
Aug 21, 2007 | Toshiba Stratagy 4 Lite Voicemail System...
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
