Spin dryer is not spinning at full speed - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,466 Answers
Could be worn motor brushes or loose belt you need to check both
Posted on Feb 08, 2010
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
How long does it take in a full cycle of wash to dry
Depends on several things. How big the drum is eg 6 kg or 7kg .the spin speed... The material ie. cotton drys faster than woollen items.is it a washer dryer or do you have a separate dryer.normal full load 6kg on a 1200 rpm spin of mixed fibres takes 1 hours 30 mins at 40 c then the dry time can take roughly 1 hour to 90 mins.
Dec 23, 2014 | Washing Machines
Spin action starts but does not reach full speed and then switches off as if programme has ended.
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
Apr 13, 2014 | Electrolux EW1200i Front Load Washer /...
For past 6 months dryer has been making a noise while drying and when I turn it off sounds like it is still spinning for a second. Now dryer is making a squealing noise as well and not drying the clothes...
Sounds like the blower wheel (fan ) is loose on the motor shaft.... that is the spinning you are hearing...
but the fan/blower is not running full speed so it is not moving enough air...
heatman101
Jan 18, 2011 | GE DBXR463EDWW Electric Dryer
WILL NOT REACH FULL SPIN CYCLE, loud hum prior to spin, starts to spin, hits second speed but will not kick into full speed.
I would suspect that you have a Motor and Motor Control Problem. This washer has a three phase motor in it and it could have one phase out of it or the Motor Control board could be bad. However it is recommended that you replace both at the same time with a motor conversion kit.
Jul 15, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
My GE profile WPDH8800J doesn't hit high speed
Your belt may be slipping and not spinning the drum to full speed to rid most of the water in clothes.
Sep 09, 2017 | General Electric WPDH8800J Front Load...
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Spin cycle won't get up to speed!?
Might be a control board problem. Contact Malber USA at 1-800-600-8913. They will have replacement part and, if the machine is still under warranty, the part is free.
Jul 08, 2006 | Malber WD1000 Front Load Washer/Dryer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
