Question about Sigma 1.133708 - Series 1300 Windsor Elite Widespread Lavatory Set
Where can i find info on a windsor elite gas fire?i need to know if it is less than 7kw output
  • 3,315 Answers
Hi these fires are old not made now there is a data badge on the front panel that lifts off but they are only about 30,000 btus
Posted on Mar 08, 2010
Briggs and Stratton 7KW House Generator can not start. Model 01897
You may be experiencing the major short fall in CNG & propane systems. The gas regulator. They are unforgiving. If used every day they stay clear and last forever. But intermittent use allows moisture to form & oxidize internal components. Valves & diaphragm start to malfunction and then the safety design of the regulator prevents it from working unless all is well. I'd be willing to bet this is your problem. Good luck.
Sep 15, 2015 | Briggs Electrical Supplies
Am told that a cozymizer gas fire installed in conventional grate now requires additional ventilation. Only id marks on plate are "18N and input 9.6 kw. Can you advise?
I just happened to be looking at this site. I have just changed a Cozymiser for a Wonderfire (remote control). For fires over 7kw, you will need a vent in the room - which will cause a through draft. Our Cozymiser was 9.2 kw and without a vent, it was against regulations to use. These regulations came in after we acquired it in 1989! Our new 7kw fire is great and a vent is not needed.
Oct 10, 2011 | Heating & Cooling
Hi there We have a Trident Excel 549 RMN fire which was already installed when we moved in. British Gas will not service the fire as we do not have the manual. I would be gateful if you knew how we...
terry, I have to agree with you. There's very little out there concerning your model Trident Fire. However, I did locate a company by the name of Trident Systems Fireplaces in the UK. Here is their website link below and their contact information. Hopefully, they can help you.
http://www.trident-systems.co.uk/index.html
Apr 13, 2011 | Heating & Cooling
Need to know firing order for 1975 351 W. FORD motor
The 351 cu in (5.8 L) Windsor...
Hope this helps (remember to rate and comment this answer).
Dec 19, 2010 | Ford Econoline Cars & Trucks
TRIDENT LPG EXCEL GAS FIRE PILOT FLAME VERY POOR AND WILL NOT RUN CONSTATLY have blown jet out etc
Hi, This needs new pilot assembly,when the fire uses lpg they have a harder time of it than with natural gas.They burn hotter and lpg is less forgiving .Let know if you need help further or parts. Will
Aug 27, 2010 | Heating & Cooling
Firing order for a 74 351 block casting d4ae-6015-aa
This all depends on whether this is a Windsor engine or a Cleveland engine. The Windsor engine has a 1-3-7-2-6-5-4-8 firing order. The Cleveland engine has a 1-5-4-2-6-3-7-8 firing order. You may want to try the Cleveland engine firing order first.
I hope this helps! :) That's a NICE old engine you have there!
May 24, 2010 | 1985 Ford F150
I need a firing order diagram for 1997 f250 351 windsor
For the 1997 Ford F250 5.8L = 351:
Firing Order:
1-5-4-2-6-3-7-8
Cylinders:
...(back)
4...........8
3...........7
2...........6
1...........5
...(front)
Distributor:
....(back)
(+).5....1
4.............8
2.............7
....6....3..(+)-screw
....(front)
Let me know if helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Mar 18, 2010 | 1985 Ford F 250
I need the Firing order Diagram For a 1995 Ford Ecoline 350 1 Ton Van
Need to know the engine size. You have these choices:
4.2 L Essex V6
4.9 L inline-6
302 CID Windsor V8
351 CID Windsor V8
4.6 L Triton V8
5.4 L Triton V8
6.8 L Triton V10
7.3 L Power Stroke V8
6.0 L Power stroke V8
TD
Mar 10, 2010 | 1988 Ford Econoline
Need info to rebuild 351 windsor motor 1998
port polish only on heads, they crack plus valve job. on the block and cam, that motors all torque so go with low end output, fat cam, 30 over max on bore-they crack. safest way for big power is a stroke kit. call edelbrock tell them you wishes and what you have now, main thing is how much your gonna have to bore to clean up walls, and they give you some good options. unless you have alota money and dont require this motor to be dependable dont expect more than 320hp and 350 ft of torque. 302 will take you farther cheaper and lighter for your money. if your talking for a car and not a truck- go 302 and dont look back
Aug 26, 2009 | 1998 Ford F150 Regular Cab
I need a control knob for a Parkinson Cowan Windsor radiant gas fire urgently please
If you have 2- knobs , just pull the one off the other to control both switches,or take the knob down to a repair , or supply house and get a matching pair, but for now, plyers! thank-you-very-much!
Aug 28, 2008 | Heating & Cooling
Sigma 1.133708 - Series 1300 Windsor Elite Widespread Lavatory Set Logo
534 people viewed this question
Top Sigma Home Experts
john h
Tom Chichester
Are you a Sigma Home Expert? Answer questions, earn points and help others
