Question about Panasonic CT-27G21 27" TV
Color problem with TV
All of a sudden the color in our set went off the norm.....everything is either green or purple. We tried to adjust everything with the remote but no luck. The set is 11 years old and it might be cheaper to just buy a new one. That is unless you have a solution that's easy & not too expensive.
  • OkiObie
    OkiObie Mar 24, 2008
    TV has been great. Owned over 12 years. Been in the same spot for over a year and a half. Turned it on the other day, and seems to be NO BLUE. For example, if I hit TV/Video, normally an all blue screen, I get a big red bulls-eye, surrounded by greenish yellow ring, with very little blue in the corners. Watching cable, same picture, just way off on color. Checked settings, nothing changed. Is the tube toast? Looking for a reason to get rid of it anyway.
    Novelist:
    Champion:
  • 275 Answers
Are you getting Green or purple or pink patches all over the screen?
This could be a problem of Degaussing. Have you placed any Magnetic source near the TV recently? Some Tape recorder or walkie talkie or a Speaker, etc? The Magnetic field created by any of the above sources can cause coloured patches over a colour TV screen.
It also happens if you shift the TV from one location to another.
The third possibility is that the Picture Tube's Red Output stage gone faulty. Unless you are a trained Solid state Electronics Technician, there is nothing you can do. Better go for a trade in.
Posted on Feb 23, 2008
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
My lcd tv has a purple screen and no sound
same problem all set to replace TV but tried another source DVD instead of dish and it was fine. Possible the cable (cheap HDMI) but reboot the dish (hard) pull the plug and fixed it up, probably the HDMI connection at the source or the TV (or the cable)
Mar 28, 2010 | Samsung Computers & Internet
No green color in Sony Wega 55inch TV
the green tube is out on the tv call a repairman in and get it fixed or youll miss the superbowl unless you want to see it all in purple...call a tech...
Jan 28, 2009 | Televison & Video
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
Colors are messed up
the deguasser in your tv may not be working right..or the magnets in the corner of your tv has moved....it can be manually deguassed but a tv shop would have to do it..
Jun 28, 2008 | Sylvania 6427TE 27" TV
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
Color sudden change
Good day.
Your unit is still worth. It may be a caused of loose contacts along the circuitry. It can be remedied by resoldering the terminals particularly the chroma section and the crt circuit.
chris
Mar 25, 2008 | Toshiba 36A61 36" TV
Toshiba MW27FPX dropped it!
See if you can borrow a TV de-magnetizer (degauss) from a tv shop...if that doesn't purify the color, then the shadow mask inside the picture tube is bad = no repair unless CRT is replaced
and that would cost more than a new TV ! ...................T.
Jan 30, 2008 | Televison & Video
Televison & Video Logo
280 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
