Question about Haier Washing Machines
I have a HAIER HW-C1470TVE-U washing machine but get a clrf message keeps coming up what does it mean
2 Suggested Answers
SOURCE: My Haier HW-C1460TVE-U washing m/c keeps giving (CLrF) ERROR Code
Anyway, my machine shows an error code "clrf". I just spoke to someone at Comet, and apparently this means there is too much foam in the machine. The machine will then refill with water and try to rinse it out, but if after that the machine still has too much foam in, then it will stop the cycle. Hence why my clothes are still wet (although I'd not realised they weren't rinsed properly either!).
I have not been using excessive amounts of washing powder, and usually use powder tablets or the liquid tablet sort, so they are a set amount and I don't do anything daft like stick 6 tablets in! I find it ridiculous that this would cause a problem with the washing machine, as I've used them perfectly fine with other washing machines.
Anyway, the advice from Comet was to keep trying different washing powders until i find one that foams less.
Posted on Mar 20, 2010
Why is my washing displaying CLrF while on a cycle?
Sorry but I do not know your particular machine but I would guess that CLrF stands for CLearFilter.
You will need to to clean the drain motor lint tray/filter. Following are my general guidance notes which include checking the motor itself which some problem-solving require ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
The machine thinks the filter is the problem so it should be- but good luck anyway!
John C
Feb 24, 2011 | Haier Washing Machines
Error code Unb: After the last rinse finishes, spinning fails completely due to unbalanced of the laundry (What does this mean) and How do I clear the error. Machine does not spin the clothes.Every thing...
I have had the same problem with the same model and rang up the help line to be told that the machine cannot sense the clothes in the drum. I tilted the machine forward and this worked for a while, sometimes i have to unplug at the wall so there is no electricity flowing through the machine for an hour and it resets itself,. Its not adequate but it works.
Sep 02, 2010 | Haier Washing Machines
Haier washing machine error 1 message does 1 mean fatal or fixable
You need to close the machine door, thats what error 1 means :)
Jun 09, 2010 | Haier XQG50-QF80 Front Load Washer
Jan 07, 2010 | Haier Washing Machines
I have a HW-C1460TVEME-U haier washing machine,it sounds af if the bearings are going at the back is there anything i can do
It is a task that you might not want to tackle. You might be better off to have it serviced to keep your sanity.
Oct 29, 2009 | Washing Machines
My haier hw-c-1460 washing machine continuously throws its drive belt off of the pulleys. What is causing this?
Have you checked the tension on the belts? Loose belts will exhibit this symptom.
If they're loose the procedure for tightening them is not very difficult -- let me know if you want help with this...
Charlie
Aug 13, 2009 | Haier Washing Machines
Washing machine finished its last wash and is no longer working ?
All HAIER Washing Machines come with a 3 year parts and labour warranty - Ring them and get them to come and repair..
Apr 10, 2009 | Haier Washing Machines
My Haier HW-C1460TVE-U washing machine was installed this morning did the empty cycle first then did a load of towels worked perfectly did another wash Err code Unb came up. Got sprit level and checked...
Have been to one of these machines today. UNB will still show even if the machine is empty. I think the feedback amplifier on the main PCB is at fault. If I have any luck with it I'll post another message
Jun 29, 2008 | Washing Machines
Washing Machines Logo
93 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
shaun taylor
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
