Question about Xerox 8830 Copier
X8830 Hello All, I wondered if I might pick your brains over a problem that has recently developed with our 8830. We are unable to print off on this machine! After sending a plot, the phrase ?PROCESSING? is displayed for what seems like an eternity. Of course, nothing happens in the meantime. In the end, I have to restart the machine to clear the display and cancel the plot. The machine is a bit low on Toner but was recently fitted with new Developer and a new waste bin. Any thoughts as to the root cause of this problem and how I might be able to rectify it? Also, any trouble-shooting info you have on this machine would also be much appreciated. Best Regards, Andy 01234 758902 07810 813494
I just went through this with my 8825. It turns out all we needed to do was reload the Firmware for the Controller (in our case the N5T controller firmware). Download the firmware from Xerox's website for your controller, and then upload it via the WebPM interface. Wait for it to load and restart on its own. That got us up and running.
I hope this helps.
Posted on Jul 27, 2008
  • 22 Answers
Check to see if the fuser is turning on and heating up.
Posted on Feb 22, 2008
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
How do I fix a black smug on the leading edge about 12 inches long, all the way across then print. It only happens on the first page on each run. All others pages are good.
Well, well, this machine was my bread and butter for years.
The black edge could be caused by the developer being U/S original life approxmatly 9 months, or an over concentrated toner / developer mix. That would need setting up again. You'll need a manual for that, or a visit from the local Xerox engineer. Do you have a wide format scanner to go with that system? Does the black edge only occur with a copy or a direct print from your CAD system?
Dec 15, 2014 | Xerox 8830 Copier
8830 Idle Message
Try to reinstall the driver. You can get the latest from the link below:
http://www.nodevice.com/driver/xerox-8830-printer/get126620.html
Sep 23, 2013 | Xerox Office Equipment & Supplies
Our card printer has suddenly stopped working. It turns on fine, but it won't pick up the cards anymore and when I try to print it reads "error". I'm wondering if it is no longer compatible...
What kind of printer is this? I've experienced the same problem with a couple different models, and every time it has been the result of bad rollers. If they're unable to pick up the cards, then you will see an error.
Feb 28, 2011 | Office Equipment & Supplies
I'm setting up a 8830 and a 7356. The scanner says ready but when I put in the paper it says not ready take out the paper. The 8830 has a code LL-22, is that something I can fix?
As far as the scanner insert a sheet to copy and when it says NOT READY instead of rolling the paper out the way you put it in, roll it forward until it comes out the back.
An LL-22 is a HV power supply error. Most of the time when I see this the corotron wires are contaminated by developer. You need to clean it with a vacuum.
Nov 25, 2009 | Xerox 8830 Copier
Computer wont connect to wireless internet
have you configured firewall let it through your firewall
Mar 09, 2009 | NEC Versa LX Notebook
Blank pages on E 35 Studio
type in the address bar
toshiba e35 copier print blank paper
enter
rod
Feb 06, 2009 | Toshiba e-Studio 35 Copier
Telus Blackberry 8830 World Edition with Rogers SIM?
Unfortunately, you can't use the current Storm model on Rogers. The Telus network is CDMA (Rogers is GSM), which means Telus' wireless products do not use SIM cards :-(
If it's any consolation, there is supposed to be a Blackberry Storm released soon that will use SIM cards and could be used on Rogers.
Dec 28, 2008 | RIM BlackBerry 8800
Blackberry 8830 Power Failure
you need to buy a new battery coz blackberry battery are not working longtime
Jul 17, 2008 | RIM BlackBerry 8800
Xc 830 problems
why not take the developer and drum units out of the skew copy one and put them in the other? At least that will tell you if dev/drum/toner is the problem.......
Skew copies on the other...look for torn corners of paper tight in the end of feed chutes etc, sometimes clearing a jam will leave a bit in there enough to slow down that side of the feed.If you can see any rollers make sure they are closed and parallel to each other and clean...
Jun 12, 2008 | Xerox 8830 Copier
193 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
