Its the J2 noise reduction. my **** did the same thing i changed it and now my **** works if u still have problem just post it here and ill go from there
to put it simple it should be right before the power supply where you plug the cord into or the male end and from the J2 it leads to power supply . they will still push power to the power supply even if they r bad. but they dont filter out enough static therfore it trips a saftey switch in the power supply and keeps it from powering up the screen as a saftey feature
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Thanks for the responce carrrules, I've asked my mate about the J2 noise reduction, and he is not sure what part(s) you mean. Any chance you can elberate? I can probably take a picture of the power supply if you like?
Had another look at it today still not fixed but made some progress maybe, this time looked at the controller board as well as the power supply, tested most/all the caps, one was slightly popped and was working at only half capacity, and another 1000uf cap was rated at 1400+ !! anyway replaced both of those and put everything back together and now it works - but only sometimes. while it was working we did a power cycle and then it stopped working. took it apart, put it back together and it worked again, until the next power cycle.
I looked for the J2 noise reduction and couldn't really find it, I found several Jumpers labled J3 onwards. possibly found a J2 under some white glue stuff. but even if i find it, what am I supposed to do to it, its only a strip of metal wire, theres nothing to replace... please help its so close to working!
