Question about Sony PlayStation 2 (PS2) Console
I need help fixing the direction pan on the controlor
The direction pad is not working
I'm no expert but i've done this several times. if you can dismantle the controller taking note of which screws go where and gently taking it apart so that you know how to put it back, the board where the direction pad rests on has, first rubber cross with carbon tips on the bottom touching the circuit board, and above this rubber thing is the plastic direction buttons which you actually press. try cleaning the board with cotton and solvent (i use alcohol) to gently get the black stuff and dust off the board.
but there are instances when the controller get so so used that the metal contacts actually get worn off. that's what happened to one of my controllers and unfortunately i have no answer to that particular problem.
Posted on Feb 09, 2010
2006 HONDA PILOT OIL PAN REMOVAL
IS HARD TO DO THE JOB ON THE DRIVEWAY BUT I WILL GIVE YOU SOME DIRECTIONS.
DISCONNECT THE BATTERY
RISE THE VEHICLE AND DRAIN THE OIL
REMOVE THE EXHAUST PIPE FROM CAT.CONVERTER.
REMOVE THE SMALL CAP FROM TRANSMISSION LOWER SIDE COVERING THE FLEX PLATE.
REMOVE THE BOLTS FROM THE OIL PAN .
CLEAN THE GASKET FROM PAN AND ENGINE.
INSPECT THE OIL STRAINER AND CLEAN.
REPLACE THE GASKET AND INSTALL 4 BOLT TO FIX TO THE PAN IN POSITION.
INSTALL THE PAN AND DRIVE HALF WAY THE 4 BOLT.
INSTALL THE REST OF YOUR BOLTS AND TIGHT SLOWLY .
REPEAT IN 3 STEPS TIL TIGHT.
IF YOU SEE THE GASKET START TO BLOW OUT OF THE PAN, STOP. IF YOU OVER TIGHT WILL BRAKE THE GASKET AND WILL LEAK.
GOOD LUCK
Apr 23, 2014 | 2006 Honda Pilot
2004 Honda STX 1300 Pan European how to replace rear brake pads
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Thread How to replace rear brake pads
ST1300 Rear brake pad change
Honda 2003 ST1300 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda Pan European st1300 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 31, 2012 | 2004 Honda STX 1300 Pan European
My Kenmore 665 has the pots/pans, hi temp and heated dry lights on. It won't cancel or start. Is there a reset button, or what would be the problem?
This means the touch pad has failed, You would need to replace the touch pad to fix this issue.
You can purchase the touch pad from the link below.
Appliance & Refrigerator Repair
Mar 22, 2011 | Kenmore 15129 Built-in Dishwasher
The trackpad does not work anymore. How can I fix it?
You would need to take the phone apart and replace the trackpad. You can find a trackpad on ebay for about $12-15. If you are interested you can contact us and send it in for us to fix it. If you buy the trackpad yourself we would just charge you for labor, otherwise we would charge you for the trackpad + labor.
www.usedcellphoneshop.com
May 18, 2010 | RIM BlackBerry Bold 9700 Smartphone
The dualshock 2 analog controller is not detected
Well its probable your controlor port either needs to be cleaned out or your controlers wire is lose.I might be easier to just buy a new controler and if the problem persists clean out the port.
May 07, 2009 | Sony PlayStation 2 (PS2) Console
STX Honda 1300 cc motorcycle brakes effectiveness
souns possible that the pads have become glazed a very light abrasive to the pad face should help wearing pads in on bikes is never the same and it depends on the type of pad you use the higher friction copper based are the better and worth looking into as they last longer and protect the disk also hope this helps you
Jan 16, 2009 | 2004 Honda STX 1300 Pan European
Directional Pad
honestly sounds like its the controller port either have to open it up and make sure everything is connect correctly around it or even blow some air into the ports to blow anything that might be blocking they come loose now and again over the years of use.
have you tryed it on the controller port 2 yet? if not try that and see if it works on that one.
Aug 20, 2008 | Sega Master System Console
PSP Directional Pad does not work
sell it. thats a mother board problem it costs 110 buvks to fix. ill buy the psp
gabrielsimut@yahoo.com
Jul 07, 2008 | Sony PlayStation Portable (PSP) Console
I need drivers
Hi there, i am going to tel you step-by-step how to get the driver you are looking for.
1) Go to http://www.limewire.com and download limewire(This is FREE)
2) Open limewire and search for "aspire 1603LM_2.6 drivers", you should get at least one qualified result for each component you are looking for (a qualified result must be a .ZIP file)download the biggest 1 of the 3.Please remember to put a good rating on my profile.
Kind regards
Dustin Ellse
Jun 26, 2008 | Computers & Internet
Mouse trouble
You'll need to replace the Palm Rest assembly to permanently fix the issue. For parts, go here: http://www.parts-people.com/index.php?action=item&id=404&prevaction=category&previd=140&prevstart=48
Jan 16, 2008 | Dell Latitude D600 Notebook
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
