Question about Drills
I have a new belt for the feed roller on a hmt-260 scheppach planer/thicknesser but i don't know how to release the tension off the wheels to fit the new belt.
Lower the infeed table to 90mm then slacken the two 13,00 mm bolts on the inside this will allow you to fit the belt and with a screwdriver as lever to retension the belt, and tighten the two bolts, after 1 hours running recheck the belt tension, these as the instructions as per the manufactures manual. and you can make a belt from a piece of flat leather, It works because I have done it.
Posted on Jul 06, 2013
Hello there J Prosser. I also have a HT260 and the belt has just today broken after 20 years - admittedly with sporadic use.
Where did you find your belts from and how did you fit it? it would be greatly appreciated if you could let me know.
MANY thanks in advance.
T Moody
Posted on Sep 22, 2010
I need all manuals for my SAC RS 63-S Surface Planer
Planers - Single - West Coast Machinery
www.wcmachinery.com/WCMACHINERY/myinventory.asp?...S...
Delta/Invicta RC-63-D 24" Planer in excellent condition. ... Table jack screw sprocketshave been replaced ... 16" single surface planer, - 5HP 208-230 volt single phase belt drive motor, - push ... with operation manual, - excellent condition but offered "as taken from service". ... 2240/440V, three phase S/N 203851 1974 year.Missing: my
Wood working machinery > Planers > Thickness planer (used)
www.machineseeker.com/2-106-65.html
Used Dickte SAC, further information will follow shortly... 2.500 EUR ... Thickness Planer, Thicknesser Huefner & Soehne 63 ... Thicknessing machine Sicar S 500... Working width: 500 mm Working height: 200 mm 2 speeds 2 Table rollers manualtable lift 4 knives - Safety shaft. ... Thicknesser mitTersawelle SAC RS 53Missing: my
Woodworking Planers - Southwest Machinery & Equipment
Dec 14, 2015 | Masonry Tools
Dewalt 735 planer trips overload a lot. New blades, thin cut no difference. Run it, without wood, it trips. Overload switch? Checked everthing. Turns free with chains off. Bluespook
id check the feed roller drive or feed rollers them selfs I find due to pressure there under most times they get flat spots in them from sitting makes for a hard start to planer
its best to back off tension rollers when storing these and keep them bearings lubed up well
and yes it happens to sealed bearings too
Apr 28, 2015 | Garden
Startrite super 260 combination woodworking machine dose anyone know where i can get a new drive wheel or rubber for the thicknesser.
http://www.tphmachinetools.co.uk/prodinfo.php?catcode=60&typecode=70&sizecode=00&uniqcode=6375&machine=U
Apr 27, 2015 | Crafts & Hobbies
Makita 2012NB slipping
My makita2012NB was also slip too. I tried to fix it out then I found if I screwed the screw under the rollers tighter it could reduce this problem.
Nov 28, 2012 | Makita 2012NB Electric Planers
When I feed the board in it stops then starts again. ever four inches. Leave a little snip in board. I've replaced the belt an the chains on the in feed and out feed still have this problem.
Couple of things to check:
1. Are your knives sharp? Dull knives will cut not fast enough to keep up with the rollers.
2. What is the depth of cut? Dewalt's planers cannot plane a board to excessive depths.
3. Are you rollers clean? Dirt, pitch or possibly grease could affect your feed rate.
4. The belt/chain for your rollers engaged or are they slipping? Open up the planer and check for wear or possibly broken belt/chain.
Snipe is usally caused by improper support while exiting the planer. Use outfeed rollers set to the correct height. Also chek that you outfeed bed is aligned with the bed of the planer.
Hope that helps,
Dec 20, 2010 | Dewalt Tools & Hardware - Others
Searching - user manual for Wadkin BAO/s planer thicknesser
www.machines4wood.com
I Also have a BAO 12 and im trying to find out about the starter as i need a new one. But the company above have a copy which i am ordering. His name is Ben Thatcher.
Hope this helps Rob
Dec 02, 2009 | Tools & Hardware - Others
Feeding speed is erratic
Researching Your Model. The Rollers are Chain Driven, but this Planer is a V-Belt Drive. Any slippage of Your Belt? Are the Chains Loose?? (there's a Drive Chain on one Side, and a Driven Chain on the Other Ends of the Feed Rollers) Never Hurts to apply a "Light" Coat of Chain Lube to these Parts(Gears & Chains)
DO NOT SAND THE ROLLERS!! Cleaning them with Denatured Alcohol is OK ( I prefer Brake Parts Spray Cleaner Myself)...the Planer Knife Head & the Front & Rear Rollers all work together as a Unit.
What Thickness are You Trying to Remove?? Usually I don't like removing More than 1/32" per pass...
Have you contacted DeWalt Service?
Jan 08, 2009 | Dewalt DW744S 10" Portable Table Saw with...
1994 saab 900 se replacing timing belt
STEP 1 Remove Air Filter. STEP 2 Loosen the bolts securing the crankshaft pulley. Remove the load from the belt tensioner by turning the belt tensioner pulley locking bolt forward in the car using a 15 mm wrench. Remove the belt from the coolant pump pulley and slowly release the belt tensioner. STEP 3 Remove the belt tensioner and remove the steering pump pulley STEP 4 Remove the water pump pulley use the engine bracket to pry against. STEP 5 Remove the timing cover and Remove the right-hand front wheel and the cover in the wheel housing. STEP 6 Remove the crankshaft pulley (undo the six bolts but do not remove the centre bolt). STEP 7 Place the engine top dead center and Zero the engine. The markings on the camshaft sprockets and timing cover should be in alignment as also should the marking on the crankshaft. Use locking tools 83 95 006 and KM-800-2 for the camshaft sprockets and locking tool KM-800-10 for the crankshaft (These tools can be purchased from Saab (18774177222) or from Baum Tools). STEP 8 Before removing the toothed belt mark its direction of rotation . To facilitate refitting the belt can be marked at both the camshaft marking and the crankshaft marking. STE9cc7b85.jpgP 9
STEP 10 Fit the toothed belt according to the marked direction of rotation. Use setting tool 83 95 006 to keep the belt in place and adjust the tensioning roller loosely by hand to prevent the belt from jumping off. Adjust counterclockwise. Fit a section of the toothed belt and fit tool 83 93 985 to measure the belt tension. Loosely tighten the centre bolts of the adjusting rollers. Adjust the lower adjusting roller counter clockwise to a belt tension of 275-300 Nm. Turning torque 30 lb.ft ft ******The adjustment of the belt tension is for preparation ONLY and must not be used as a check when the belt adjusted for the final time! STEP 11 Turn the engine over two revolutions until just before the zero mark and place the locking tool on the crankshaft. Carefully turn the crankshaft in the direction of engine rotation until the arm rests against the coolant pump's flange and then tighten the arm. Fit setting tool 8395006 and check that the markings on the camshaft sprockets are aligned with the markings in the tool. ********Check that the A marking is approximately 2mm above B marking. If the distance is less readjustment is necessary. STEP 12 Fit the crankshaft pulley and Tighten to a torque of 15 foot lbs. STEP 13 Reinstall the inner wheel cover and front right wheel.
STEP 14 Reinstall Timing Cover.
STEP 15 Reinstall the water pump pulley use the engine bracket for leverage. STEP 16 Reinstall the power steering pulley and tighten to 6 foot lbs. STEP 17 Reinstall the belt tensioner and tighten to 30 foot lbs. STEP 18 Remove the belt tensioner load/pressure by turning the belt tensioner pulley locking bolt forwards in the car using a 15 mm wrench. Install the belt on the coolant pump pulley. Carefully release the belt tensioner. STEP 19 Reinstall the Air Cleaner and hoses that accompany Release the belt tension and remove the toothed belt.
Jul 18, 2008 | 1994 Saab 900
Drills Logo
321 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
