Question about Gigabyte GA-7VKMP Motherboard
I want to add a grapic card to my motherboard..
Motherboaard type gigabyte GA-7VKMP..
what type of graphic card i have to use...
  • 1,675 Answers
You will need an AGP type graphics card for this motherboard, not a PCI-E....hope this helps
Posted on Feb 08, 2010
Testimonial: "thank you man "
    Problem Solver:
  • 19 Answers
You may purchase any brand/model AGP slot video card. The higher the memory the better.
My monitor has some problem with windows 7 ultimate. it is showing "out of range" why is this?
Hello you can try to seach for the driver here:
http://www.hclsupportservice.in/drvr-dwnld.jsp?pF=RGVza3RvcA==&pC=RXplZWJlZQ==
By entering the pc`s model number.
If the driver is not listed you windows is not supported.
Try to run windows update it sometimes find the driver for you.
Look in the device manager for driver fault.
You can also try to lower the screen resolution in screen settings or install a graphic card on the mainboard.
Just make sure your windows system is supported.
Good luck
Dec 15, 2012 | Gigabyte GA-7VKMP Motherboard
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
GA-7VKMP via sound can not install and its not
With what OS? XP / Vista / 7, or linux?
This is an old board, so probably only up to XP support.
If you are trying to find later OS drivers, your sound chip is ac97, you may find drivers by using google
http://www.giga-byte.co.uk/support-downloads/download-center.aspx?kw=GA-7VKMP&ck=
Jul 26, 2010 | Gigabyte Computers & Internet
Wont start monitor
The Gigabyte GA-8PE667 Ultra MB will only run certain AGP graphics cards. Check you manual. See page 1. Click the next link to open your manual; http://europe.giga-byte.com/FileList/Manual/motherboard_manual_8pe667u_e.pdf
To view your manual you'll need the program, Adobe PDF reader.
You can download Adobe here; http://www.adobe.com/products/reader/
If you install anything other than an AGP 4X, (1.5Volt) graphics card. Your system may not boot up normally, if at all. Just because you tested your graphics card in another system does not mean the card is compatible with the GA-8PE667 Ultra. The link below will show a compatible graphics card for your Gigabyte GA-8PE667 Ultra;
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3281698&csid=ITD&body=MAIN#detailspecs
Cheers!
Mike
Nov 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
Cant get an resolution more than 1024x768
With just running the Integrated Graphics that's on the motherboard? This is normal. If you want larger resolution, I suggest you install a graphics card that is capable of it.
[Also be sure your power supply has the required power cables, Wattage, and enough Amps for the 12 volt voltage rail, for the graphics card you install)
Aug 19, 2009 | VIA GA-7VKMP (MB-GA-7VKMP) Motherboard
2000 pro will My GA-7VKMP motherboard machine running Win will not boot into BIOS orWINDOWS 2000 Pro
well, do the capacitors look distended? (bent out of shape, bulged, burst etc.) is the power supply good? (sufficient power rating, new) other than that the only thing i can think of is that your bios is no good
May 26, 2009 | Gigabyte GA-7VKMP Motherboard
My multimedia audio controller is not installed
http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?
Please download teh required drivers from this site.
Please donot forget to rate this as Fixya.
Mar 30, 2009 | Gigabyte GA-7VKMP Motherboard
Need system bios update for Gigabyte"GA-7VKMP mobo.
Hi bhscam,
Try this it should help you out: http://www.wimsbios.com/phpBB2/topic6731.htmlut:
I hope this helps.
Thank you for using FixYa.com
Sincerely, cyyyd7
Oct 11, 2008 | Gigabyte GA-7VKMP Motherboard
Gigabyte GA-7VKMP Motherboard Logo
118 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
