Question about Dell 3100cn Laser Printer
Dell 3100cn streak on left side of paper
I am getting a streak down the left side of the paper about 3/4 of an inch wide. It doesn't always show up on printed test, but it always appears on a photo.
  • express04 Feb 22, 2008
    This has been happening for some time and getting worse as time goes on. It appears on everything but is much worse on pictures.
    How do I find these roller parts and directions to replace them.
    Thanks
    Genius:
  • 3,422 Answers
Just pull all the cartridges out of it and tried to clean it throughly. IF not you have to replace the drum and the cleaner may also be bad.
Click HERE for the user manual for some troubleshooting steps.
Main support number: 888-560-8324, 800-624-9896
Goodluck.
Posted on Feb 22, 2008
  • Priya darshan Feb 22, 2008
    Hi again,
    You can buy the roller parts from HERE
    For the drum,cartridge and any other things you can buy it from HERE
    I am sad to say that there is no service manual avsailable for your model you have to contact dell for that u have given you the contact details.
    Goodluck,
    Please don't forget to rate me as fixya..
    Master:
  • 788 Answers
If this has happed with more than one cartrdige than you probably need a charge roller replacement.
Otherwise replace your cartridge.
  • 1 more comment
  • Dean Joly
    Dean Joly Feb 22, 2008
    I would bet it's the charge roller that is contaminated, not to expensive and easy to replace. May also want to get a transfer roller for good measure too. Or you could replace the entire maintenance kit, that way you cover all your bases and refurbishe the machine at the same time.
  • Dean Joly
    Actually did you try the cleaning instructions found here: http://support.dell.com/support/edocs/sy...
  • Dean Joly
    Since it's just the black then it's probably not the drum, actually doesn't look that there is a charge roller/transfer roller on this model. Hopefully the cleaning takes care of it. Good Luck!
    Scholar:
  • 121 Answers
Hello..
I would definitely check your margins on the printer and also look at the properties of the photos you are printing bc they may also be set a certain way. Does this happen on every photo you try to print? If that is the case, then it is definitely something with the settings on your printer or the picture itself. It may take a little time but I think this should resolve your problem. The other thing is your camera could also be going bad, i had one that did that so check that last. Also, if you had to install any photo software for the picture/camera you have, then uninstall it and reinstall the software.
I hope this helps!
d
  • donna mcgill Feb 22, 2008
    definitely try to replace cartridge once all else fails since it can be a little expensive i thought you could try some other troubleshooting b4 any $$ has to leave your pocket.. i hope this has helped you.. d
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
When printing, the toner does not completely get distributed. Consequently we are left with a "white" line through the print on the right-hand side. The white begins about 7/8ths inches in from edge and...
It can either be the toner cartridge itself, or the fuser.
Try a full cleaning, and if that does not help at all, you will have to replace the toner or fuser or both.
Apr 07, 2010 | Dell 3100cn Laser Printer
Dark streak
clean the glass lining. It is situated on the left of the glass when you open the document feeder...clean it with a damp cloth
Nov 17, 2009 | Xerox DocuPrint N17 Laser Printer
I have a Dell 3100cn printer that seems to always print with a thick gray streak down the middle of the paper. Apparently, the drum was replaced a couple months ago and this problem only began recently. ...
try the cleaning rod. goto: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
and see the instructions under "replacing the cleaning pad" to access the cleaning rod. You likely do not need to replace the pad. To use the rod, pull it out and push er back in 10X.
Cheers
Jul 08, 2009 | Dell 3100cn Laser Printer
Drum kits marking up and streaking the paper
You can check with Dell to see if there is a maintenance kit for this printer. I know that there is one for the HP counterpart. You will probably need to replace the fuser, and maybe the pickups and rollers, but as I said I am not sure if Dell has a maintenance kit for these machines.
May 26, 2009 | Dell 3100cn Laser Printer
I'm getting a streak of ink down the paper
change a toner.
when you have the toner out. clean the heater element (glass). make sure the printer is off and the heater element is cool before you do this.
May 14, 2009 | Dell 3100cn Laser Printer
Dell 3100cn Smudges on all color except black
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
149 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
